CPU Bored so dellided the 6700k
Discussion in 'Hardware' started by jizwizard, 22 Mar 2017.
  1. jizwizard
    jizwizard Modder
    24 Dec 2010
    Decided to delid my 6700k to see what temps I would get. Used razor blade method. Once cleaned used coolabratory ultra between the die and IHS then used go extreme on the heat sink. Results in pic.
    before
    after
  2. David
    7 Apr 2009
    What pic?
  3. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Delidded 7700K here. No brainer using a Ncase M1. Bought it like that, although I have been known to chop them off using the same method. Let us know how you get on.
  4. jizwizard
    jizwizard Modder
    24 Dec 2010
    Is the picture not showing?
    Idle temp 32c down to 27c
    Max temp 80c down to 63c
    Both run on intel stress test for a quick 10min blast
  5. GeorgeK
    18 Sep 2010
    The pic is showing - it's just hard to make out the results. Excellent improvement!
  6. David
    7 Apr 2009
    Really? Something must be wrong with my browser.
  7. theshadow2001
    3 May 2012
    I've highlighted it and put a circle around it for your convenience
    Margo Baggins likes this.
  8. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    I have a standard 6700 (non K), so it doesn't really get warm anyways, but if R5 doesn't do what I want it to (or they just don't release any fudging motherboards!) and I migrate this setup into the ITX case I have I will no doubt give this a go myself - just to take the edge off.
    Seems to be a fairly good average of 15-20% cooler from the results I've seen, that could be the difference between a CPU running during the winter vs spring in terms of ambient delta.
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
    God knows why it's doing that lol.
  10. theshadow2001
    3 May 2012
    God told me your have your image folder permissions set to private.
  11. mrbungle
    20 Sep 2004
    Pic is too tiny to make out anything.
    That said when I popped the lid off my i7 6700 I got a 40 degree drop (100 to 60!).
  12. GeorgeK
    18 Sep 2010
    That might explain it - perhaps mods can see private images :thumb:
  13. jizwizard
    jizwizard Modder
    24 Dec 2010
    Will update the pics when I get home from work
  14. jizwizard
    jizwizard Modder
    24 Dec 2010
    pics should show now
