Scratch Build – In Progress Rasberry Pi Competition: Bulky - Completed 15.3.2013
Discussion in 'Project Logs' started by tekonivel, 30 Jan 2013.
  1. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    Hey!
    Here we go. my first ever case build.:dremel:
    Decided use 5mm acrylic since i had sheet lying in the corner. going for a bulky look. and it will be open from the sides, (will be leavin the option for side panels), but now for ventilation they stay gone.
    so here is the basic layout drawing.
    ok got done with the jigsawing. there are two pieces on top of each other. The future legs and spacers holding them together for now.[​IMG]
    that is it for now. i am waiting for my unc 6-32 tap to arrive so i can tap the "mobo" mounting holes.
    Till next time fellows.
    Asouter likes this.
  2. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    am i only one who cant see pix?
  3. Ehlers
    Ehlers What's a Dremel?
    13 Feb 2012
    I can see them just fine.
  4. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    nice to see some finnish modders! good luck in the competition!
  5. tekonivel
    14 Jul 2012
    thank you!
    have been following your work as well.
  6. Cheapskate
    13 May 2007
    Oh, dear! Now I will have to re-think my entry.
    Looks good so far.:thumb:
  7. tekonivel
    14 Jul 2012
    thank you.
    jump in. more the merrier.
  8. tekonivel
    14 Jul 2012
    Ok. to keep you updated.
    I have had really hard time trying to get the tap drill. finaly got one in order now.
    Have couple of ideas while waiting, will show them after the weekend.
  9. tekonivel
    14 Jul 2012
    I was thinking of edging the acrylic with wood like edging tape. not sure yet because it was pretty hard to get clean looking trim. Here is a practice piece.
    What do you guys think? I might want to get something a bit darker.
  10. faxiij
    faxiij Minimodder
    25 Jan 2011
    you could engrave a hundred tiny raspberries...if you were that bored? :D not sure on the tape. how about trying some dark wood like teak and glue on some tiny strips?
  11. tekonivel
    14 Jul 2012
    i was trying to get my hands on to some dark thin wood strips, but the local store had nothing in stock. i might just end up painting the edges if I'm not happy with the tape.
    And with my engraving skills, ill will settle on some lettering, but more on that later.
  12. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Why would you buy a tap for mobo standoff in plastic?
    Take a 2.5/3mm drill and you can screw the mobostandofs easely in! it taps his own thread :D
  13. tekonivel
    14 Jul 2012
    Tried that. But I kept having really bad results with it, having the standoffs leaning in one way or another. and the tapdrill will come in handy in future mods or builds. got the bug now:dremel:, just had to start from something small.
  14. legoman
    legoman breaker of things
    28 Feb 2010
    Could do what i did, drilled them and set the standoffs in using plasiweld
  15. tekonivel
    14 Jul 2012
    dont have even solderin iron yet. but thanks for the tip:thumb:. that would have worked.
  16. tekonivel
    14 Jul 2012
    small update
    Hey guys. i decided to go with the edging tape. And it actually looks better when i did the whole edge than on the tryout piece.
    Took me a while to trim it. Still a bit ruff but i'll do the finishing touch after i can remove all the protective tape.
    I also did these for the led that I am thinkin of installing.
    Just took 3 pin connector an cut it in half and trimmed it to be two single pins. led will be connected the GPIO.
    Tried out to engrave some random letters too,
    obviously i need more training in that.:D
    Till the next time.
  17. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I do believe you have a chance of winning this competition!
  18. tekonivel
    14 Jul 2012
    Thanks! :D
  19. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    Do ya need to have the rasberry pi it self for the contest or just to make a case for it?
  20. tekonivel
    14 Jul 2012
