Scratch Build – In Progress CM SupreDesk
Discussion in 'Project Logs' started by TheL4mka, 6 Oct 2013.
  1. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Hi, I'm new here, so sorry for some mistakes and my english :D
    FINISHED - final pics on page 2!
    My PC was very noisy when I played games, so I was thinking more and more about creating watercooling rig, but it was rather dream. Few months ago I need a new desk and in the same time I saw L3P's projects (L3p desk, Cross by Redharbinger).. So I decided to make my own desk including computer with water cooling.
    SPONSORS
    With PSU V850 and 4x JetFlo 120 red fan.
    With EK-HD fittings and angle adapters.
    GTX770DC2OC
    With Alphacool radiators and few special fittings.
    Thank a lot to sponsors. I can't finis this project without these parts.
    I spent hours figuring out how to do it all. Next days I was making some sketches in Google Sketchup and after that and then I finally drew everything in AutoCAD.
    CURRENT PROGRESS
  2. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    FIRST UPDATE
    After laser cutting and bending the "main" part of desk, I bring it home and test it little bit :D
    Everything started on this nice laser cutter
    And continues on this powder coater :)
    Finally at home!
    Testing some old MB and fans, everything fits as I wanted. :)
    After that I must do slot for MB. I used back part of old Eurocase.. :idea:
    I cuted off all unnecessary parts
    then I resurfaced it.
    And test it into lasercutted part. :)
  3. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Hi,
    I am pleased to introduce a new sponsor - Aquatuning. They joined the project with beautiful radiators and special fittings.
    Thanks a lot to this company! :)
  4. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Looking good!
  5. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE
    Making the HDD holder, I try so much options and this is the best imo.
    Painted with RAL9005 and test in in desk :)
    I also paint the MB slot :)
    I started sleeving PCIE and 24PIN.
    6pin PCIE
    24PIN + waiting for black connector
  6. Andreas | Brodholm
    Andreas | Brodholm Minimodder
    12 Jan 2013
    This looks very good! I really like that you made extra space for your legs. That is the main issue I have with desktop builds.
    Looking forward to the final results!
  7. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE
    Last week I was very busy, because I was making the desk from wood. I am not so good in wooden works, so I made the desk with my friend in his factory.
    That is him! :D
    Wooden part of desk is made from material Egger1137ST (oak).
    Afterk co-op working with me friend i bring the desk home. :)
    COOLERMASTER SPONSORED PARTS
    Thanks a lot Cooler Master for their help and for sending me PSU 850V and 4x JetFlo 120 Red Fan. Enjoy photos of CoolerMaster quality products!
  8. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Looks great! get your hardware it there.. can't wait to see this finished.
    J.
  9. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE
    I am here with next update. I added to desk switches for ledstrips, on/off button and fan regulators. There are 3 photos of empty desk with switches.
    In this photo are mentioned switches. From left: on/off button, on/off button for left fans, on/off for led strip, on/off red strip, on/off strip on back of monitor (not decided which color).
    These are 90mm cutted threads for holding the desk with reserviors.
    They will hold this desk with reserviors.
    Arrived package from Aquatuning.de
    Thank a lot to this company for radiators and few extension fittings!
    Started to install radiators. UT30 Full Copper 360 on left side.
    And install CoolerMaster fans.
    UT60 Full Copper 360 on right side.
    Install Scytche Gentle Typhoon fans.
    And the doted aluminium cover :)
  10. Knighthammer
    18 Feb 2011
    Looking pretty awesome! I like the blend of wood and metal.
  11. l3p
    l3p www.^.nl
    1 Nov 2010
    Following, awesome idea man :)
  12. hakank
    hakank What's a Dremel?
    28 Oct 2013
    The efforts that goes into these desk builds is truly magnificent :D
  13. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    really like the aluminum rad covers.
  14. CM Tim
    CM Tim CM Rep
    1 Nov 2013
    Good progress! I am looking forward to see the finished build :)
  15. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE
    I did not have so much time last 2 weeks, so here is new update. At first I done electrical wiring to FANs and led strips. And try red and blue lighting.
    I started to completing steel parts. Desk for reserviors and steel bulkhead (wall)
    And with closed top.
    Made holes for threaded rod to hold desk for reserviors. Looks good imo.
    SPONSOR UPDATE
    Arrived awesome package from ASUS Czech Republic :)
    GTX770DC2OC
    Installed Alphacool D5 pump on place.
    FIRST TUBE
    Tubing with John Guest push-in fittings, working with them beautifully.
    And made drain port.
    Connect the first reservior to the loop.
    And the second reservior connected.
    View on tubed part with the wall. :)
  16. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Inspiring work there chap, well done. What are you thinking of using for coolant?
    J.
  17. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Thank you HackJoe! :) I will use Aquacomputer Double Protect Ultra Red
  18. Knighthammer
    18 Feb 2011
    I love the desk! I assume that the accessory wiring it temporary and will receive proper attention?
  19. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    SMALL UPDATE
    Hi, I am very busy last weeks so I post only small update :)
    Arrived blocks and fittings from EKWB. So I installed them.
    Small army of EKWB Fitiings :D Thank you so much EKWB for them!
    EK-RAM Monarch X4 - Acetal+Nickel CSQ + EKWB Fittings
    Installed EK Water Blocks EK-Supremacy - Nickel Acetal + EK-HD adapters
    Started with tubing. 10/12 Acrylic pipes and EKWB Fittings - working with them is beautiful! :)
  20. keenan
    keenan Minimodder
    12 Nov 2013
    This is looking very good so far TheL4mka!!
