Case Mod - In Progress Project Arclight
Discussion in 'Project Logs' started by tobyak, 24 Feb 2012.
  1. tobyak
    tobyak What's a Dremel?
    5 Jul 2011
    Behold my latest creation to be
    Project Arclight will be a huge case built on an Enermax Fulmo GT chassis with some serious power behind it also provided by Enermax in the shape of the mighty Platimax 1200watt psu
    Te Arclight will be an all acrylic outer shell with a double action doors and servo actuated fan intakes that will open and close based on fan speeds, the shell will have a double tone look with layered panels of black and flourescent blue to accent every edge even the 100s of vent parts will have glowing edges, the interior will be a partitioned system very much like the custom partition for my other project "Sulaco" but with far more refinement
    Much of the details i would like to keep slightly underwraps untill I post them for that extra mystery, heres a little peek at the exterior
    several sponsors are already assisting me on this build and there help is as ever massively appreciated i simply would not be able to do this without them
    Acrylic and solvent supplied by Hindleys. These guys are amazing, catering for 100s of different types of materials from plastic to metal and everything in between. And allays happy to answer even the craziest of questions a modder like me can ask
    Massive thanks to Enermax for supplying a Fulmo GT, Platimax 1200wall and a vast array of case fans from there amazing Vegas range
    Thanks also go to Bitfenix for givign me so much on my last project that i have enough spare to add to Arclight
    Stay tuned for a lot more to come........
  2. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Its always nice to get stuff for free :)
  3. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    looks like it's going to be crazy acrylic time! =)
  4. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Nice design. Looks very sharp.
  5. tobyak
    5 Jul 2011
    IT is going to be a pretty hard build, over 100 parts on the intakes and i need to add all the pull rods and actuators
  6. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Nice one ! Subbed for sure !
  7. tobyak
    5 Jul 2011
    WoW a lot of time has passed since i was last able to get on this project, such a busy year
    Well that was then this is now, and its all go from here, hew hardware, new materials, new tools
    Arclight was origionialy designed for the Enermax fulmo GT a huge and brillicnt case, but time has marched on and Azza have offered me the chance to use there superb Genesis 9000, so a little redesigning was called for,
    Concepts for the intakes have been redesigned to better fit the new chassis and all the electronics have been brouht in and in some cases teaching myself arduino voodoo
    Heres the first batch of parts going in to the chassis
    the origional blade design and array have changed slightly from this
    to this
    The array control mechanism of a pull rod attached to a servo will remain much thesame as the origional
    Some parts will need to be scrapped or completely changed to fit the new body shell such as the origional concept for the sides [​IMG]
    the new version will be a wait and see but they look great in the planning
    Well this project will need a huge number of mechanical and electronic parts in top of your typical PC set up
    This arduiuno kit courtesy of Phenoptix is a great start to the project and will be controlling several of my lighting systems including a rather clever hack of a LOL shield
    LOL shields and old school bar graphs will be making quite an appearance as accenting lights, and yes there will be larson scanners
    Servos and actuators will be making a big appearance including several mechanized fan intakes and a large front panel "shield"
    And to wrap up this update and REBOOT, Kingston have graciously given there support and provided some of there swesome products
    the amazing HyperX 120gig SSD
    and a quad kit of DDR3 2400MHZ RAM
    Stay tuned
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    I simply don't understand why I hadn't subscribed to this project log already.
    Oh well - error corrected!
  9. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    exciting! I'm going to be using micro controllers and similar gear in a build I'm working on designing still. I'm stoked to see what you come up with!
  10. tobyak
    5 Jul 2011
    Cheers dude. what kind of gear will you be using? the servos in this will be run by a Pololu 6 channel controller controlled via usb wen set to manual and by its on board processor when on auto, i am powering it with a modified molex rigged to only run on the 5v wire (more amps then USB)
    http://www.pololu.com/catalog/product/1350 a lot cheaper then using an arduino shield and can control 6 rather then 1
  11. tobyak
    5 Jul 2011
    Just a little update today
    An absolute ton of cutting and sanding today
    Well i dont have access to a lazer and i need a lot or duplicate pieces to were rocking it old school with a stencil
    And what better to cut out my many many parts than a home made table saw, complete with mitre fence
    Problem.... no sharpie..... solution... stick paper to plactic cover on acrylic and use engineering pencil... copy template.... move.... repeat.... over, and over
    and now its on to cutting
    first up divide the sheet up in to manageable blocks
    then drill holes for turning the cutting blade in
    some more cutting to further separate each component
    first half done, all rough cut
    bit of refining the shapes to reduce sending
    sanding time...... 1 of 24
    and yes that is a dyson taped to the extraction port
    all done for the day, 24 pieces of the main intake array rough cut and rough sanded
    i may never want to see acrylic AGAIN after this build....
  12. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Thats alot of cutting...
  13. Cheapskate
    13 May 2007
    Awesome concept.:D
    -Personally, I wouldn't shape the parts too accurately until you get the layers glued together. That would make 3X less sanding and shaping.
  14. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    I say that all the time....
    Good work so far Toby!
  15. sixfootsideburns
    6 Feb 2009
    nice man, sounds like your a lot futher into planning than I am :hehe: I'm thinking I will probably use a Pic controller because I have an extra kicking around my house somewhere. My needs for the motor are pretty simple though, and I might end up going with a different solution. This is for linear movement not rotary, so slides, springs and dampers might end up being the better way in my case.
    Looks like your making some awesome progress though man, keep the updates coming!
  16. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    One of these days, they'll make a Sketchup mod that models the lighting too.
    Subscribed. Mod on my friend.
  17. sixfootsideburns
    6 Feb 2009
    Well thats what rendering software is for isn't it? Or maybe I don't understand what your getting at
  18. Gentleman_Dingo
    30 Aug 2007
    You can get Sketchup to show the light and shadows cast by various light sources and how they interact with your modeled parts?
  19. tobyak
    5 Jul 2011
    damn, ive not been getting my updates on replies so sorry for late get backs
    @Cheapskate Well ahead of you dude, spotted that early so i broke out the WW2 era Russian glass syringe and the dichloromethane. results in next update ile have up over the weekend
    @Kylevdm this is just one grill..... 3 more smaller fiddely ones to go
    @sixfootsideburns i know a great UK online store to get actuators, the stripped down motor with threaded shaft versions, there not pretty or refined but they are dirt cheap and have enough power for PC use
    @monkeyfun learn solidworks ya bum
    next update over the weekend, keep em peeled, and Kyle/Cheapskate ile see you on the podcast
  20. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Great idea on the slats! hope you dont mind if i steal that idea for the plans on my first build, if i can get my ass lit on fire and get a job.
