Scratch Build – In Progress Project: Fan Job
Discussion in 'Project Logs' started by TheGreatSatan, 29 Apr 2014.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    First work log ever with all just cell phone pics!
    So I'm setting up my modding space in the garage at my new home. And, I'm not remotely done moving so the contest winners are gonna have to wait.
    In order to make this space useable I first have to put up my motherboard wall.
    As I'm working on this I start to get really hot. I look around at all my computers surrounding me and I'm seeing fans in all of them, but yet there's not a floor fan or ceiling fan for me. I don't have any of our floor fans at the new house yet and it's midnight, so I'm not going shopping for one.
    I have no idea how to add a ceiling fan in my garage, but can I build one? I mean, I'm surrounded by fans? So I get out four 200mm Cooler Master Fans.
    Then I position them so all the wires are in the center and I begin to tie up the cabling every few inches. I then pull out a couple of 90 degree bars and a flat one too
    I start cutting them working the pieces into a frame
    Each corner gets one screw and nut to keep them in place
    Back to the wiring. I need to adapt these four three pin connections to molex's.
    Then I need to add splitters to make two connectors into one. There's four fans, so I need two splitters which leaves me with two molex's. So I adapt it again into just one molex connection for the PSU. This adaptation has helped give me the cord length I'm going to need.
    Now that I have the right cord length, I add the flat bar on top to keep it all contained.
    I'll be using a heavier chain to keep the fans from making the frame sway. Once they're cut to the right length I add hooks to the ends
    It's nearly one in the morning and I'm getting beat, but luckily Yoshi is here to keep my spirits up
    I then drill out holes in each of the four corners for the chains to loop into
    To power the fans I use an old power supply that has been jumpered via internal soldering so it fires up without a motherboard. I have it resting on an ISA card that is inserted into one of the old motherboards on the wall
    The chains to the fan are each added to a master hook in the ceiling and it works!
    Now I'm feeling a lot cooler to finish my motherboard wall just after 2 a.m.
    -fin
  2. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
  3. trintragular
    trintragular What's a Dremel?
    29 Oct 2012
    How well does it work? Is it noisy?
  4. morgansk
    morgansk I've got wood
    12 Jan 2013
    Motherboard wall - now there's a cool idea!
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Man Cave with mobo wall, led ceiling fan and a small beast to protect it.
    WIN WIN WIN :)
  6. TheGreatSatan
    5 Aug 2005
    Dead silent
  7. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Could not ask for a better mod-room, looking great so far. :clap:
  8. trintragular
    29 Oct 2012
    That's good to hear. (Sorry, couldn't resist.)
    Let's hope it doesn't cause your ceiling to fly away... :D
  9. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    What a fantastic mod!
    Sorry
  10. Cheapskate
    13 May 2007
    A fitting LED encrusted crown for the ghetto king!:D
    -Although usually a king's tapestry is of triumphs, not failures.:lol:
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Much cooler than regular ceiling fan & using an expansion card as a shelf, awesome. :D:dremel:
    Nice modding room & that motherboard wall would make for nice unique background photos.
  12. Deblow
    Deblow Minimodder
    12 Dec 2013
    lol, glad i clicked on your post now. the name suckered me in at first then the massive fans :D
    Nice one!
