Hardware Fermi Testing Update
Discussion in 'Article Discussion' started by Lizard, 31 Mar 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Thanks for the update! ;)
  3. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    This is why I read Bit-Tech over other places, you guys really care that the info you are providing is correct and holds water :) Good work guys.
  4. cjoyce1980
    cjoyce1980 What's a Dremel?
    17 Jul 2007
    looking at this, ATI card seems to be more constant staying around the 60fps mark.
    it would be interesting to see the GPU load of each card as this might be a driver control foring the game to play around the 60fps mark.
    just a thought anyway
  5. knuck
    knuck Hate your face
    25 Jan 2002
    just so you know :)
    (from the first paragraph)
  6. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    GRRRRRRR
    :p
  7. Bursar
    Bursar What's a Dremel?
    6 May 2001
    Useful. Now throw the 5870 2GB into the mix and see if a larger frame buffer helps :)
  8. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Thanks for the update Bit!
  9. wyx087
    15 Aug 2007
    +1
    also, it's surprising to see GTX480 dropping in frame rates when gone to Dx11. is it because the Polymorph Tessellation Engine taking up the shader resources?
    but GTX480 did so well in the Heaven tessellation benchmark.
  10. Scootiep
    Scootiep Minimodder
    9 Aug 2007
    QFT! I have always trusted Bit-Tech's testing methods far more than other sites. Their dedication to accuracy is second to none.
  11. xMathiasD
    xMathiasD What's a Dremel?
    15 Mar 2009
    +1 ! :D
  12. Baz
    Baz I work for Corsair
    13 Jan 2005
    It doesn't, at least not at 1,920 x 1,200 with 4xAA and 16xAF we've used here - identical results when I ran a quick checkup.
    The 2GB is designed for super high resolutions (hence the eyefinity edition) and you likley won't see improvements below 2560x1600. We've got a full review coming though, with testing at Eyefinity resolutions, so look out for it.
  13. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    Here's the reason so many other reviewers are reaching different conclusions: Intel Core i7-965 processor (3.2GHz: 133MHz x 24), some of your benchmarks are CPU limited, sites that use overclocked testing systems tend to show the GTX400s in a better light. Chances are that it is the 133 base clock that's holding things back.
  14. Guest-16
    Guest-16 Guest
    Yea but on the other hand - how many people can afford a Core i7? And not everyone can or will overclock - and to what degree of overclock? It introduces many variables and we should review components for what they actually are. :)
  15. javaman
    javaman May irritate Eyes
    10 May 2009
    Was gonna ask, whats causing that hit to performance when the x16 AF is addeded? is it lack on memory, poor design or bad drivers?
  16. Instagib
    Instagib Minimodder
    12 Mar 2010
    +1
    couldn't of said it better myself.
  17. Bursar
    6 May 2001
    That's the million dollar question I want answered. I'm about to jump to an eyefinity setup (3x 1920x1200), so will I see any benefit from the extra memory, or should I save the cash?
    The initial reviews I've read indicate that at the res I'm looking at, there is no real difference between the 1GB and 2GB cards. But more reviews to help me make my purchasing decision are always welcome, so I hope the BT review appears soon :)
  18. javaman
    10 May 2009
    Would be nice to throw crossfire into the mix then. Also wonder what processor is needed to drive cards too.
  19. munim
    munim What's a Dremel?
    30 Oct 2006
    I just wanted to say, you guys are awesome.
  20. Autti
    Autti What's a Dremel?
    29 Oct 2009
    Thanks bit-tech, as others have already said, the fact that you bother to update us with more information is a true credit to the depth of your reporting.
Tags: Add Tags
