Cases big high airflow case
Discussion in 'Hardware' started by xxxsonic1971, 3 Oct 2011.
  1. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    Hello all,
    i've been building me pc bit by bit for a while now, adding extra bits when i could, so far i have an, i7 920 @3.5, asus p6t, 6gb 1600 ram, xfx 850w psu, h70 watercooler kit, 2 hdd's and 2 optical drives, and 5850 crossfire. I have all this crammed in an nzxt apollo case, i have cut an extra 120mm fan hole on the side panel, but i gotta still run all fans loud to keep gpu's under 50c. Any suggestions on a nice big case with lots of airflow??? I like big stuff!
    many thanks,
    brian.
  2. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    You didn't give a budget but a Coolermaster HafX is a good starting point.
  3. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Have a look at the Silverstone range and as said, the HAF-X.
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    As other's have said Silverstone RV02/03, FT02, Haf X or Haf 932 if you like that sort of look, or even the Xigmatek Elysium
  5. stefan442
    stefan442 Minimodder
    14 Mar 2011
    +1 Xigmatek Elysium
    Can fit that big ass fan on the side panel :D
  6. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I'm running a HAF 932 and whilst it's a beast of thing I kinda like it. Undersated just that little bit not over the top like other cases. Reasonbly quiet too. Plus loads of room for tidy wiring. And comes with 4 fans already fitted. xD
  7. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    I know its a bit old now but for cooling the Antec 1200 is still there with the best of them. Just check out the bit tech review of the latest cases and you will see the 1200 near the top
  8. thetrashcanman
    18 Nov 2010
    agree with this also, was going to suggest it, but feel the 1200 is a bit dated now, although I think antec have just done a v3 version with USB3 and i'm not sure what other changes, but I used to have one and I must say it was a very good case for air cooling :)
  9. Bede
    Bede Minimodder
    30 Sep 2007
    Coolermaster 690 II.
  10. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Raven rv02/3
  11. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    you can have too much airflow going in the wrong directions sometimes
    I made the mistake of adding three 120 fans in the side panel of my Lian Li PCa77 (the big one probably some more letters or numbers in that I have forgot) and it made it worse
  12. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    this was gonna be my suggestion as well
  13. Blarte
    15 Jul 2008
    Cheap yet excellent case .. dremel ... some spare ally .. great looking case
  14. djzic
    djzic Bokehlicious!
    8 Nov 2010
    TJ07, if in reach :D and some better WC...
