Hello all. I have a server running WHS 2011 that has two raid arrays that house my vitals. One of the arrays houses my music store which I then stream from my main pc and a media pc. Whenever I play music over the network it lags out, every 30 secs or whatever it stops then starts. If I move the folder and stream off another PC it stops, so I think the problem is the server. However everything looks fine? Any ideas?
Straight cat 5 through a Virgin superhub. Think I got to the bottom of it, had a process that would max out the Celeron from time to time but I had to be logged in to see it as I streamed media. Think I tracked down the service and associated program but was about 1 am when I did it so cant exactly remember which it was.
Nice one. While you're at it check your cat5 cable, I've seen frayed/chewed cable cause similar symptoms.
