Windows The Guide to Make Bootable USB
Discussion in 'Software' started by TheBlackSwordsMan, 29 Jul 2010.
  1. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    This guide is for Windows 7 or Vista
    1# You Need a 4GB USB Drive (plug it)
    2# Open the Prompt Command CMD
    3# DISKPART (Enter) ---> LIST DISK (Enter)
    Ex of Disk List :
    Disk 0 596 G
    Disk 1 931 G
    Disk 2 4096 MB
    4# Choose the USB and type SELECT DISK 2 (Enter) ---> CLEAN (Enter) ---> CREATE PARTITION PRIMARY (Enter) ---> SELECT PARTITION 1 (Enter) ---> ACTIVE (Enter) ---> FORMAT FS=NTFS (Enter) ---> ASSIGN (Enter) ---> EXIT (Enter)
    5# Note your DVD Drive assigned letter ex: D PS: If you have an Image and not the CD, don't forget the mount it before.
    6# Promt Command again, D: (Enter) ---> CD BOOT (Enter) ---> BOOTSECT.EXE /NT60 F: (Or whatever is your USB Assigning Letter)
    7# Copy paste your Windows from your CD to your USB.
    8# How to boot on the USB ? Go on your BIOS ---> Advanced Bios Feature (Thats for my board) ---> Hard Disk Boot Priority (Chose the one ex: USB-HDD0: KingstonDataTraveler2) ---> First Boot Device (Chose USB-HDD)
    Now you are in Business, nore more CD and no More scratch.
  2. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Or just use wintoflash and let it do everything for you :D
  3. TheBlackSwordsMan
    16 Aug 2009
    Of course but its only teach you one single thing, How to Hit INSTALL lolll
  4. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    I prefer the Original Poster's method. You learn something from it :)
    16 Aug 2009
    Hahaa I'm using my own thread, 2 years later. I love me !
    wolfticket likes this.
  6. GeorgeK
    18 Sep 2010
    Congratulations past you :thumb:
  7. TheBlackSwordsMan
    16 Aug 2009
    Still usefull 5 years later loll
  8. Xir
    Xir Modder
    26 Apr 2006
    Holy Threadnecro-Batman!
  9. _crazy_crazy_
    _crazy_crazy_ mi mum say's that i'm special
    1 Feb 2007
    lol or if you want to put more than one in a usb you could always use yumi
  10. TheBlackSwordsMan
    16 Aug 2009
    Currently doing a bootable USB to load Vista x86 on a XPS M1210 with the intention of upgrading it into a free Windows 10 32bits.
  11. TheBlackSwordsMan
    16 Aug 2009
    Well it didn't worked, the XPS is half dead and I just learned that you can't upgrade from Vista to Win 10 for Free : ( Only 7 and 8.1.
