Windows Userfriendly interior design software
Discussion in 'Software' started by Sheiken, 6 Jan 2011.
  1. Sheiken
    Sheiken Wat?
    9 Jan 2005
    The title pretty much says it all! I just got a great idea for the living room and I need some software to help me visualize and design the interior.
    Any suggestions?:thumb:
  2. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Google Sketch Up.
    There are loads of models made by people already so you should be able to find tables, sofa etc, if you don't fancy doing them yourself.
    You can even use your own jpegs to paper the walls.
    I am supposed to be doing our front room atm but can't drag myself away from LOTRO.
  3. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  5. Hazmatt
    Hazmatt What's a Dremel?
    4 Dec 2010
    MyVirtualHome
    It's free! (for non-commercial use)
    I use it myself although I'm not an interior designer or architect, only play around for a bit of fun.
  6. kylesaisgone
    kylesaisgone What's a Dremel?
    23 Oct 2010
    +1 for Sketchup
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    +2 for SketchUp.
  8. bluespider42
    bluespider42 Minimodder
    2 Jul 2010
  9. Alastair3
    Alastair3 What's a Dremel?
    9 Jul 2011
    Nice thread.,
    I thinks the IKEA Room Planner is the best ever userfriendly interior design software.,
  10. anora
    anora What's a Dremel?
    22 Jul 2011
    Yes...
    I also check this IKEA Room Planner personally.. really its great software for user-friendly interior design software...
  11. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    the sims 3
