Other Torrent advice!
Discussion in 'Software' started by jopers1986, 3 May 2009.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    Hi Guys!
    Never used torrents before... and want a piece of SW, any advice you could give me?
    what to use etc?
    Thanks
  2. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    uTorrent. Bsolutely. Lightweight and a shitload of options.
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You're downloading a Linux distro or something, right? (the thread is going to get locked otherwise :p )
    Yes, download µTorrent. Start it up and it will propably ask for connection configuration or something. Choose your connection speed and use all other default settings. You might want to limit your download and upload speeds to 90% of your max speeds because otherwise it'll get clogged and slowdowns will occur.
    Then just get the .torrent file and open it in µTorrent and choose where to download. It'll start automatically and download.
    Here's a quick guide, but bittorrent is pretty advanced and you'll have to mess with the settings to get the best configuration.
  4. Krikkit
    21 Jan 2003
    Good advice tbh. Set your upload to leave between 10 and 15KB/s for your other browsing, otherwise it slows everything down.
    One other thing - SEED AFTER YOU'VE FINISHED. Biggest trouble with torrents is people who don't seed (aka leechers).
  5. azrael-
    azrael- I'm special...
    18 May 2008
    Wouldn't want someone not getting their new Linux distro... :D
  6. Krikkit
    21 Jan 2003
    Doesn't matter what it is. The whole idea is that it needs people to share.
    On Tuesday, for example, I'll guarantee that the number of leechers on the Win7 RC1 will be enormous. :\
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    helps to increase the max connections per to 150.. yeah agree set upload limits, 4/6 while seeding and leave around 10k for yourself (up)
  8. docodine
    docodine killed a guy once
    10 Feb 2007
    uTorrent, or a pre-Vuze verion of Azureus. My friend swears by BitLord, but I can't stand the advertising.
    I liked Azureus better than uTorrent, but the latter is far more lightweight.
  9. jopers1986
    7 Jan 2005
    Of course i am! :D
    cheers for the help guys! Hugs all around!
  10. jopers1986
    7 Jan 2005
    it comes up with access denied...?
  11. Krikkit
    21 Jan 2003
    Nothing wrong with post-Vuze Azureus. Tools->Options->Interface->Start->Show Interface Chooser cheesecake. :D
    jopers: You've probably found a torrent from a private tracker. Try another.
  12. Akava
    Akava Lurking...
    28 Jul 2007
    Exactly what i was about to say, at first i loved the new styling of Vuze when they brought it out, then it just began to get very annoying very quickly, found out how to change the interface and haven't looked back since.
  13. ComputerKing
    8 Sep 2006
    Private Trackers Cheesecake
    And yeah uTorrent is the best ;)
  14. smc8788
    smc8788 Multimodder
    23 Apr 2009
    The RC1 hit the Torrents last week, but yeah, most people either don't care about seeding once they have what they want, or don't understand how this whole P2P thing works :sigh:
  15. BlackWhizz
    17 Jul 2008
    For linux distro's :) Nice!
    Absolutely Utorrent the webUI is nice. Thats so handy because uTorrent is running @ my Server.
  16. ComputerKing
    8 Sep 2006
    That's Why Private torrents rocks because they force you to seed :lol:
    EDIT :
    I wish if they make it for all ;) but so far windows and beta mac.
  17. azrael-
    18 May 2008
    I used to use Azureus and liked it very much, but after trying uTorrent I wouldn't want to go back. I do miss the SafePeer functionality, though. Sure, you can specify an ip filter file, but you have to maintain it manually.
  18. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    I'm all about the Transmission... especially love the webUI a lot, moreso since they made it play very nice with iphone safari
  19. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    rTorrent is where its at, gui pah :D
  20. mm vr
    18 Nov 2007
    The µTorrent EXE is a few hundred kB in size. Azureus is coded in Java, hence it uses TONS of RAM.
