Windows Will office 2010 work if i upgrade windows
Discussion in 'Software' started by rici1241, 2 Nov 2012.
  1. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Hi.
    I plan on installing windows 8 pro on my laptop, which is currently running windows 7.
    I want to do a clean install, and wipe the hard drive.
    I currently have office 2010 home and student installed.
    As this is the single licence version, if I upgrade, will I have to get a new product key for it to run, or can I use my current product key.
    Thanks for any help. :)
    Richard
  2. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    upgraded my win7 pc to win 8 (and selected "keep documents only")
    I had to reinstall office 2010, though it hasnt asked me for my serial number again since, and ive used various bits of office several times since being on win8.
  3. kenco_uk
    28 Nov 2003
    No you will not have to purchase a new key and yes you can use your current product key.
    The issue would arise if you were to use the key on two different PC's at the same time, specifically when activating the product using the key.
    Ensure you back up your emails (unless you use webmail, natch :) ).
  4. GoodBytes
    20 Jan 2007
    Office 2010 will work perfectly.
    It just has 2 graphical glitches. There is a strange glow on the "File" button, and the shadow around pages in Word, is just solid gray box and not smooth.
  5. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Thanks :thumb:
  6. kenco_uk
    28 Nov 2003
    Ah yeah, I noticed that, the square box on the File button. It doesn't stop it from working at all, just seems to be a small visual bug.
  7. GoodBytes
    20 Jan 2007
    yea. I have been using Office 2010 (mostly: Outlook, Word and Excel), and I haven't fell into any issues beside these strange visual problem. I doubt MS will fix them as they want to push Office 2013, but its just minor thing. Program still works perfectly.
  8. longweight
    7 May 2011
    I am doing the, keep all files, settings and apps option so hopefully it will all be ok!
  9. Nexxo
    23 Oct 2001
    Should be. If you forget to back anything up it will most likely still be in the Windows.old folder after install.
  10. longweight
    7 May 2011
    It was ok :) Windows 8 is awesome!
  11. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Working perfect. Thanks for the help.
    I'm not getting any of those visual glitches at all.
  12. sWW
    sWW Minimodder
    3 Apr 2010
    From my experience if you do encounter an error with your key being rejected a call to Microsoft support will normally sort it out.
  13. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Hi again.
    Every time I open any of the office programs (Word, Excel, PowerPoint), I get a "Configuring
    office home and student 2010" loading screen, which takes a minute to complete.
    Whats causing this, and how do I stop it.
    Thanks again
    Richard
  14. GoodBytes
    20 Jan 2007
    Try and run it as true admin, wait until it's done. Make sure Office is activated. Then close it, and open it normally. See if it solved the problem.
  15. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Still doing the same thing. I repaired the suite from the control panel, and that also made no difference.
    It is activated and running perfectly, except for the configuring screen.
    Any other ideas?
  16. GoodBytes
    20 Jan 2007
    Did you clean install Win8? Or did you upgrade?
    You might need to re-install Office 2010 (uninstall it first).
  17. rici1241
    rici1241 Minimodder
    4 Jan 2011
    I upgraded, and chose keep documents only.
    I downloaded the office 2010 60 day trial, and used the same product key as before.
    Anything else needed, or will I just uninstall and re-install it.
  18. GoodBytes
    20 Jan 2007
    Hmm I don't know. I am out of ideas right now. :/
  19. Nexxo
    23 Oct 2001
    Apparently not an uncommon problem. Add the following key to the registry:
    HKCU\Software\Microsoft\Office\14.0\Word\Options /v NoReReg /t REG_DWORD /d 1
    That should do the trick.
  20. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Just after uninstalling it. Ah well. Thanks for the help. I'll reply in the morning and see if it works.
    Thanks again
    Richard
