News AMD Bulldozer chip allegedly benchmarked
Discussion in 'Article Discussion' started by arcticstoat, 6 Jul 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Woollster00
    Woollster00 What's a Dremel?
    24 Aug 2010
    Would you be tempted by an AMD FX system with this level of performance? Does the Bulldozer architecture have any hope of competing with Intel's Sandy Bridge and LGA2011 processors?
    No and No.
  3. stoff3r
    stoff3r What's a Dremel?
    20 Nov 2006
    This level of performance... Oh well, If it's cheap and cheerful then.
    BTW when's LGA2011 coming out? In time for Battlefield 3?
  4. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    So what have we lernt from this article,
    We have an unidentified chip, running on beta drivers from a Czech site whos credability is unknown.
    Think im gonna get more info befor selling my AMD shares : )
  5. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Wow - not even 2% in it and people are writing off bulldozer on PRE-PRODUCTION parts? idiots, seriously. Wait until the retail parts hit the shelves before making a judgement folks.
  6. GeorgeStorm
    16 Dec 2008
    As above really, wait until more testing has been done.
    And tbh, if it comes in at £200, then near 990x performance for that isn't DREADFUL now is it.
    We know so few details, waaay too much speculation.
  7. wyx087
    15 Aug 2007
    as soon as i read quad-SLi, i have written off any credibility in these benchmarks.
    use a single GPU to remove any unoptimised drivers. multi-GPU technology rely HEAVILY on drivers, and at end of the day, drivers are just lower level x86 code running on CPU. so optimised driver for CPU architecture can make quite a bit of difference.
    also, 990x isn't exactly flagship when compared single-thread gaming performance of sandy bridges.
  8. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I'm interested to know how he got 4-way SLi to work, given that a slide earlier on in the article says the chipset only does 2 or 3 way SLi. Also, why no EFI BIOS? Surely this should be a must have on a top end chipset?
  9. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    They're using SLI, their argument is invalid. You've got to wonder - are they testing CPUs or GPUs here?
  10. TheUn4seen
    TheUn4seen What's a Dremel?
    22 Oct 2009
    Damn, that's one huge socket.
    As for the article - I want Bulldozer to be earth-shattering, but I don't expect it to be. Actually, I think it will be like Phenoms, first gen will be a complete disappointment, second will be better but still poor. So, for the second time in many years I just bought an Intel CPU (2600k). Now, how about that Zotac Z68-ITX review you promised? I need a worthy replacement for my insane little H55N-USB3.
  11. Technobod
    Technobod Minimodder
    28 Oct 2010
    Ok then, lets be really generous and say that a production part has 15% better performance than a pre-production sample.. fair? ok, that still makes this 'top of the range' and overclocked chip slower than an 1156 OC'd setup.
    But agreeably and SLi setup is not the correct way to assess a chips performance.
  12. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Just games tested? Nothing to test the power of 8 cores over 6? Pre production model, and it still overclocks to 4GHz? I draw no conclusions at all, other than waiting for a proper review.
  13. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    SLI is new on AMD CPUs and Boards is it not? This also seems an odd way of testing the system.
    Both systems were overclocked to 4Ghz...
    Maybe this chip can be overclocked above SandyB levels easily and thats where its true performance lies.
    I think a better test would be to overclock each chip as far as possible and then run a proper set of CPU benchmarks.
  14. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    1) The chip is unreleased, as is its proper bios.
    2) SLI is flaky and underperforming on 990fx boards
    Does everest stil report the L2 and L3 caches as disabled on this sample? Like all the other benchmarked engineering samples we have seen?
    HMMMM YES WELL I DUNNO MAYBE WE SHOULD RESERVE JUDGEMENT THEN EH
  15. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    So Bulldozer can almost match the performance of Intel's CPU architecture from 2008? Sounds great, where I can sign up?
    I bet they're lolling their asses off at Intel.
  16. Boogle
    Boogle What's a Dremel?
    8 Mar 2002
    So the i7-990X has 6 cores and costs £800 on it's lonesome. The FX is likely to be a lot cheaper, and doesn't require a super-expensive motherboard, and has an additional 2 cores. Quite frankly if the FX CPU is as cheap as it should be, I can't see a problem at all.
    OK AMD aren't beating Intel outright. However, the AMD Radeon series seem to be selling well despite not being faster than NV's fastest.
  17. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    While I didn't expected Bulldozer to beat Intel X58 platform at all; Benchmarks of CPU with GPUs oriented/heavy setup is completely pointless. True power of CPU is tested when you using good old PCI VGA. Why do you think best OC board on the market (Gigabyte X58-OC) is equipped with 1 PCI slot? Because it is required when you want to see how CPU really performs (and with extreme OC - LN2 it is a must). All stuff which potentially clogs up PCI-Express has to go if you running serious benching session in search of true CPU performance. One of many reasons why good old PCI shouldn't die.
  18. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    Just to clarify: within 2% of the 990x performance for over £400 less. Wow.
  19. BlackRaven
    BlackRaven Freaking printers!
    20 Feb 2010
  20. SexyHyde
    SexyHyde Minimodder
    24 Jul 2009
    Well at least it ain't a proper turkey. Now we just have to wait for proper chips, proper tests and a price mark. I think with all the slating bulldozer is getting, a few people might be pleasantly surprised.
Tags: Add Tags
