Hardware Mac SSD performance and TRIM in OSX
Discussion in 'Article Discussion' started by Sifter3000, 1 Jul 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Hmmm interesting, as an owner of a late 2009 MB Pro, what I'd really love to see is whether there would be any difference with a brand new "out of the box" SSD compared to the one you guys received in the Air. I've got a mechanical HD in the lappie at the mo, but would really love to see a 256GB SSD in there.
    Is it "possible" that the SSD you tested was so thrashed by other reviews, it was suffering as a result? I don't know, maybe some built in "wear leveling" at it's maximum?
    It feels to me though that TRIM isn't really needed on a MB (At least with the SSDs apple use). I wonder if that statement still stacks up when installing your own SSD.
  3. mi1ez
    mi1ez Modder
    11 Jun 2009
    It's just as well the results don't drop on the dirty SSD since the throughput's so low to begin with! still, good for battery life and noise, eh?
  4. DarkFear
    DarkFear What's a Dremel?
    14 Oct 2003
    Would be interesting to see a comparison between the "stock" SSD and a "normal" SSD that you can buy in a shop or something...
  5. fodder
    fodder Minimodder
    20 Feb 2009
    I assume being a mac that you cannot take the SSD out and repeat the tests on a PC?
    Also, being Apple, you will not get specific answers to performance unless it is a positive result. Believe me, I have worked with them for many years. If it doesn't make them look good, no-one seems to know.
  6. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    Wow, I'm completely unimpressed yet again by Apple performances.
  7. aron311
    aron311 What's a Dremel?
    14 Jul 2007
    Having just bought a MacBook Pro, I'd love to see you test with a few other off the shelf SSD's to see how they compare! Thanks for this!
  8. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    With that conclusion on the importance of the OS on the SSD performance over time, I have ta ask a linux based OS test to see what comes out.
  9. Sifter3000
    11 Jul 2006
    It's possible, but we did reformat the Air using an option in the OS X installer that sets all the bytes in the disk to zero - it's effectively the same low level format we do for SSDs when testing them under Win 7.
    Retail SSDs in Macs is next up I think :)
  10. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Why didn't you install an off the shelf SSD in the Macbook Air to compare to the one supplied?
    Did you try disabling journaling to see if it had any effect on the performance?
  11. Sifter3000
    11 Jul 2006
    Cos the Air doesn't have a 2.5in SATA connection of course :p
  12. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    Surely you can get your hands on a macbook pro
  13. DaveMon
    DaveMon The end is nigh! Repent!
    21 Jun 2010
    Isn't the implementation of Garbage collection more important.
    As the drives will keep themselves tidy regardless of the OS or filesystem?
    eg. the OCZ Vertex and similar.
    The firmware supports TRIM and GC.
  14. Cei
    Cei pew pew pew
    22 Mar 2008
    Definitely need to see what happens when you put a retail, new, modern SSD in that 2008 MacBook Pro you have sitting around for podcasts. The Air is well due for an update, so I'm not suprised its SSD is dating from 2008...
    As a side note, you can get off the shelf SSDs for the Air, but they're not exactly common due to the size (The Air uses physically smaller drives, think the old iPod 1.8" HDDs).
  15. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Earlier Airs used a sata-LIF connection (pretty much only used by Apple AFAIK) but the rev B's used a Micro Sata which you can get adapters for
  16. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    It would probably be a good idea to install Windows on the Mac using bootcamp and test (using all of your usual Windows tools) just to see if it's OSX being good or the SSD doing something freaky.
  17. digitaldave
    digitaldave What's a Dremel?
    30 Jan 2009
    had my OCZ vertex SSD in macbook pro for almost a year now on snow leopard and can report 0 slowdown, it is used daily too.
  18. capnPedro
    11 Apr 2007
    TRIM is unimportant is when deleting files the OS actually deletes them. I.e. resets the data on the SSD to 0s rather than just deleting the file's pointer in the filesystem's File Allocation Table.
    As a followup, you could test a non-TRIM enabled SSD under Linux with an ext3/ZFS filesystem (filesystems that never need to be defragmented too).
    Uhhhh what? 138 is like 53% of 258. Performance plummeted by an astonishing 47%.
  19. Sifter3000
    11 Jul 2006
    Gah, sorry, fixed. :S
  20. mark_dsp
    mark_dsp Access to HF, bones are overrated!
    24 Jun 2010
    I did wonder if it might be related to file structure in the way that Linux's ext 3/4 copes much better with fragmentation than Window's NTFS/FAT therefore needing significantly less defragging, if indeed any at all is needed.
    However checking back over a few articles from Linux magazine it would seem earlier SSDs still struggled with early kernels due to a lack of TRIM support. I would guess therefore that the logical explanation is either that OSX has TRIM or the SSD is too slow to notice any significant changem which I guess in a way is an astonishingly long way of saying.... what he said!
Tags: Add Tags
