Modding "Fabric" sleeving
Discussion in 'Modding' started by phinix, 4 Dec 2012.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Guys, I saw in somewhere in some projects those kinda fabric sleeving but forgot where.
    They were very thin slim, made of fabric or sth.
    Where can you buy those things in UK?
  2. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Have a look online for paracord dude, lots of colours, but it not a nice material to sleeve with, plus it fluffs up and looks crap after a while.
  3. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Shoelace?
    Sent from my GT-I9100 using Tapatalk 2
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
  5. jay2
    jay2 Indonesian Modder
    3 Oct 2012
  6. phinix
    28 Apr 2006
    Paracord! Yes, that is it.
    Is it really that bad after a while?
    I wanted to use white one...
  7. jay2
    3 Oct 2012
    ask him how much "a while" is that? I've been using a very cheap paracord like fabric sleeving for 3 month, and nothing really particular happened.
    But yes, white fabric tend to get dirty easier if you have dirty work space when you sleeving.
  8. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    well, strictly from a apparel industry perspective, the paracord type woven sleeves are mainly made out of polyester or cotton or blend... i prefer to stay with the synthetic fibers as they tend to keep fibers together better and does not create lint that cotton fibers can cause.
    nylon would be preferable... not sure if paracord sleeves are made of nylon, but being stronger fiber than poly, perhaps the load bearing ropes uses nylons.
    how to test if nylon or cotton or poly? well, hard to describe but burning the fibers and smelling it... if it extinguishes and you see ashes, it's cotton... if the fibers are fueling the fire and remains a burnt lump of plastic, it's either poly or nylon...
    difference between poly and nylon, well, different odor... but again, hard to describe over the internet.
  9. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    good advice above, will be sleeving in the new year so a helpful thread indeed.
  10. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
  11. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I agree with synthetic. Try some nylon multifiliment.
    It has a very dense and tight weave and looks fantastic.
  12. Hukkel
    Hukkel James' minion
    20 Dec 2012
  13. KoSoVaR^
    19 Dec 2010
    Hahahaha, its swedish :p
  14. phinix
    28 Apr 2006
    Those are very nice.
    I wonder if you can buy them in UK.
    I remember you used them in your chocolate project, really nice stuff.
  15. KoSoVaR^
    19 Dec 2010
    Yes indeed they are, hw has stopped manufacturing and i was the one who bought his last Fabric sleeve, i still have the brownish looking fabric left if you want some :)?
    Its awsome that you remembered it, have you seen monobits ? My new project link is on my sig, it has grey and white text just click that
  16. phinix
    28 Apr 2006
    I'm actually after white sleeving.
    Chocolate temptation is awesome - when you gonna update it?:dremel:
