Nope I don't see anything. Beside the picture is so small. The only thing I see is that the red dots makes the letter T on it's side if you connect the dot, or 2 triangles. I mean really I don't get it. All I say is that OP is high on drugs.
CT hidden in the shadows in the corner 'above' the corpse. Just so you know, brightness of the monitor has zero impact on the brightness of your screenshots. You'd have to be taking a photograph of the screen for that to be a factor.
I can see it now its been pointed out, but so what. Tweek ingame brightness, not monitor and he's easily visible
How bright you set your brightness will have no effect on the screen grab brightness You're dumping the output of the GPU, not the monitor itself. incidentally, I see nothing brick worthy in that either.
That's a terrorist. Minimap is a giveaway. "Counter Terrorist" from the game Counter Strike:Source. The hidden player is behind the corpse if you consider the picture to be a representation of a 3D space, in the actual picture, taken as a 2D image, it's above the corpse. Anyway, can we stop talking about this now and lock the thread? Worst excuse for a thread since Xeb posted anything
