News Microsoft teases $299 virtual reality headsets
Discussion in 'Article Discussion' started by Gareth Halfacree, 27 Oct 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. veato
    veato I should be working
    15 Jan 2010
    Will this launch around the same time as the Xbox 'Scorpio' I wonder?
  3. Vault-Tec
    30 Aug 2015
    Will it work on a PC?
  4. Gareth Halfacree
    4 Dec 2007
    Err... They're literally PC VR headsets, designed exclusively for use with Windows 10. Now, the real question is "will they work with the Xbox One," which gets a resounding "if they don't then Microsoft's missed a trick and is letting Sony grab all the budget-conscious living-room VR market," which seems unlikely but not impossible.
  5. Vault-Tec
    30 Aug 2015
    Oh wow cool man. Well that's me holding on then.
  6. Stelph
    Stelph Minimodder
    24 Dec 2007
    It would fit with MS's continuing shift of the Xbox one towards Windows 10 - How close is the Xbox OS to windows 10 now? I know the're supposed to be sharing apps soon?
    Agree that MS could pull a blinder with this one, both the Xbox S and Scorpio are arguably the better option over their equivalent PS versions due to featureset like 4k blueray, if MS add VR support then you could see them clawing back a lot of market share they lost early on
  7. Vault-Tec
    30 Aug 2015
    That's the sort of price I can drop the bomb on without there being any fallout whatsoever. Any more and I have to start explaining and I CBA.
    Don't mind waiting. All good things etc. It also looks a lot smaller and therefore possibly lighter. This is good.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    And none of that annoying external camera stuff to add more cables:clap:
  9. Guinevere
    Guinevere Mega Mom
    8 May 2010
    "Inside out" tracking is the future. A reasonable resolution camera and a 'normal' room with enough detail to key off and you'll get 'good enough' positional accuracy.
  10. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Definitely takes care of seated experiences, but wouldn't you still need some kind of receiver for hand tracking like the vive sticks though?
  11. theshadow2001
    3 May 2012
    Its called simultaneous localisation and mapping. You use details in the room to track the position of the camera. You only need the camera and you can do it with just one camera. Basically the camera identifies features in the image and keeps track of them in the images as they appear to move (relative to the camera). By comparing where the features were in the previous image to where they are now in the current image, its possible to calculate the position of the camera. Augmented reality and mobile robots have been doing it for years. You'll probably find some form of it in most commercial drones. Its a very complex and interesting field.
    https://www.youtube.com/watch?v=Y9HMn6bd-v8
  12. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    This might be a silly question, but I keep seeing these funny looking code-type lines in posts. Having quoted you, I see now it's Youtube-related, but does that mean the original link is broken in my browser from your post?
    Edit: Oh. In the forums, it shows as a video, but on the article comments it shows as "Y9HMn6bd-v8"... why?
  13. theshadow2001
    3 May 2012
    oh yeah. I forgot about that. We can't embed videos on the main page. I usually add a link to the video if I remember.
    Basically the main page comments section doesn't have the required code to add embedded video where as the forum does. But the two are still linked, so you get the basic text from the from the forum post including the embedded video codes as a comment on the article. That's basically why it happens. Also I use the forum to comment on articles which is why I forget to add a link if I post a video.
  14. ModSquid
    16 Apr 2011
    Aha! Nice one - that's been bugging me for years. I should have just asked!
