Dear Bit-tech .. Here's some pictures of the final result of the "Corsair|Slick 01" Build, That was a side project i was doing for a client, while working on my "Parvum|Beast" This was a client build, so had to buy the watercooling and everything for this case A bit pricy but I'm pretty sure my client will appreciate it when he sees the end result Final Images Hardware Specs: CPU: AMD FX8320 clocked at 4,6GHz for now, GPU's: 2 x GTX 680's 2GB in SLi Mem: 4 x 4GB = 16GB of 1866Hz HyperX Fury PSU: Corsair HX1050w PSU SSD: 120GB Kingston for OS and alot of other stuff that i will add in later I did a little modding on the case, that is a Corsair Spec 01 case, hence the name Corsair|Slick 01 I had my dremmel working on cutting the 5.25 bay cover off, i seriously dont understand why they still make this ! after that i Painted the 2 x 240mm Radiators White, so it suited the black/white sleeving that i also made for this build . Must say i am pretty happy with the result of the sleeving and rads, looks awesome together! And off cause i had to get black and white memory sticks also ! .. I'm all about that matching details I am also not a fan of messy cables comming out of the PSU, so obviously i had to use my heatgun, bend some 3mm acrylic sheet, to work as a PSU cover, and for the final touch i took some Carbon look vinyl and coveret it with.. again pretty happy with the result .. After that i just had to implement a little more carbon look vinyl, so i covered the SSD disk in it, made a little frame and mounted it on the rear panel, so it would be visible in the case .. I wasnt sure about what to do for tubing, but am a big fan of solid tubing because it just looks more clean. So i bend some 12/10 EK solid tubing and added the black/uv blue fluid, and DONE ! For now i'm just going to put up the pictures of it And will upload the few pics i have of the actual build stage. Dont have many because my main focus has been working on the "Parvum|Beast" machine. I am sorry for the low quality of the pictures with the UV light turned on, but its just soo hard to capture the real effect on camera Also this build is packed with alot of EKWB waterblocks and fittings that i bought just love EKWB ! looks so good! The sleeving is from mainframe customs. the LC teleios sleeving Hope you enjoy Regards, BeckModZ
