Graphics Best Graphics Card For £150
Discussion in 'Hardware' started by Carper, 2 Jul 2010.
  1. Carper
    Carper Guru
    19 Aug 2009
    Hey guys looking at getting a new graphics card. I have about £150 to spend on one. I have been looking at cards like the 4890, 5830 something like that. It would be nice to get directx 11 but if i get more performance out of games without it then i would prefer that.
    My screen resolution is 1280x1024 but I'm planning a upgrade soon on the monitor and it will be something like the dell 2209wa so ISP panel around the £200 mark so you can guess the resolution i will be playing at.
    The games i play are World of warcraft, mass effect, left for dead, crysis and a few more. Basically i would like to play most new games on the highest resolution.
    Thanks for any help given. If you need more information let me know.
  2. bagman
    bagman Minimodder
    18 Apr 2009
    wait for the 460GTX then decide between a 5830 and a 460
  3. Carper
    Carper Guru
    19 Aug 2009
    Whens the planned release of that?
  4. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    12th this month.
  5. Carper
    Carper Guru
    19 Aug 2009
    any idea what the price will be?
  6. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    Fudzilla speculates the lesser 460 wil be about £160/170 with the full fat 1gb flavour about £25 more:
    http://www.fudzilla.com/graphics/graphics/graphics/the-gtx-460-1gb-to-be-around-€30-more-expensive
    Couple of problems:
    Fermi has yet to give a power/price/heat/noise/value return. The 460 is unlikely to buck the trend so either it wont be upto 5830 levels of performance... that's the Ati card it's aimed at! (Nvidia aim high yet again!) and or Fudzilla is out on the price... given €160 equates to £150 approx ya gotta wonder! Care to speculate?
    Meanwhile:
    http://www.fudzilla.com/graphics/graphics/graphics/nvidias-gtx-460-is-768mb-one
    The version you gonna want, full fat, is gonna be delayed while 465 stocks are run down. Yes it's Fud again but that site seems to have a "special" relationship with Nvidia!
    Basically, all this 'wait for the 460' smacks of 'wait for fermi' ...dejá vu anyone?
    My advice: find a new or nearly new 4890 with an aftermarket cooler (like mine :eek:)) that or find some extra pennies and get a 5850 OR wait til autumn and see if/what Ati do next.
  7. Carper
    Carper Guru
    19 Aug 2009
    something like this then XFX 4890
    I have seen a 5830 for sell for £135 here im not sure if its new or anything what do you think?
  8. raxonb
    raxonb Minimodder
    5 May 2009
    5770 Vapor-X? It can be overclocked to perform like an 5830 and with the Vapor X the card will remail cool and silent.
  9. rollo
    rollo Modder
    16 May 2008
    4890 vapor x on eBay last night for £70 check if it's still there it's faster than both cards and you can overclock it to 5850 speeds ( within 1fps )
    Best deal I could fine for 5830 was on. Scan they were after £145 cooler was stock though
  10. Sendaii
    Sendaii What's a Dremel?
    3 Jul 2010
  11. Carper
    Carper Guru
    19 Aug 2009
    i not really wanting to buy a graphics card of ebay but thanks for the help
  12. Sunrise
    Sunrise What's a Dremel?
    17 Jun 2010
  13. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    Why is there any reason to wait for a card that is definitely going to be less powerful!? The only Fermi cards possibly worth getting are the 480 (for pure performance) and the 470 (for SLI scalability), but ATI's cards have them beat by miles for price vs. performance.
    5830 is the best (new card) you'll get at this price point and nothing in Nvidia's Fermi range is going to change that. 4890s and GTX280s are good bets for older hardware.
  14. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    What evil merc said.
  15. MrGumby
    27 Apr 2009
    Or at that resolution a 1GB 5770 is fine
  16. Zaim
    Zaim Minimodder
    18 May 2010
    +1 I'd get the 4890 if you don't care about DX 11
  17. Carper
    Carper Guru
    19 Aug 2009
    I was going to get a 4890 till i looked on the internet and its meant to be quite loud. I looked at a few youtube videos and it does seem quite loud. As my computer is now quiet i dont really wanna put a loud graphics card in it. Ill have a look into the GTX 280 though looks like a good card.
  18. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    The Sapphire 4890 Vapor-X is cool and quiet but I think they cost more than £150. The reason the standard cards are loud is due to the fan, caused by the heat. Getting one with better cooling is going to be quieter.
  19. Carper
    Carper Guru
    19 Aug 2009
  20. Fingers66
    30 Apr 2010
    Never seen/heard of them. They have a contact number (on the "Contact Us" link) so give them a call and suss them out. Ask them about the card to see if it is stock and if it is actually that price, then ask about delivery. Try a google for anything posted about the site and see what comes up.
    If you do end up buying from them, make sure you do it with a credit card to ensure you are protected.
