right, when i first got these my 920 was kicking them out at similar speed to a gpu unit [couple minutes per frame], now i'm struggling to get a frame done in under an hour and as the majority of the points for these units come from the bonus [the unit itself is only worth 88 points] it's not good. anyone else having problems with these units?
Those and a few other wu are giving me about half the points I was getting a week ago. No idea why - it started after a reinstall of windows, and all my settings (OS and fah client settings) are the same. I think it's just a coincidence though, I think Stanford changed something.
hi, see here: http://foldingforum.org/viewtopic.php?f=19&t=20535&start=0 http://foldingforum.org/viewforum.php?f=19
UPDATE: Re-downloading/updating the core seems to have solved the problem, back to normal after 3 expired and countless dumped units
