Windows Powershell/Command Prompt check default printer
Discussion in 'Software' started by noizdaemon666, 8 Sep 2016.
  1. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Hi guys,
    I have a Windows PC at work which keeps changing its default printer. I know how to change the default printer using powershell, but I'd like it to sit in the background and everytime it changes, change it back.
    I'm guessing this is really simple, but it's too early for my brain right now :D
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    This is rather quick but seems to work:
    Code:
    #Set printer name
    $printerName = "\\server.domain.com\printer-name" #can be got from $printers below
    #Get the infos of all printer
    $Printers = Get-WmiObject -Class Win32_Printer
    Write-Verbose "Get the specified printer info."
    $Printer = $Printers | Where{$_.Name -eq "$PrinterName"}
    If($Printer)
    Write-Verbose "Setting the default printer."
    $Printer.SetDefaultPrinter() | Out-Null
    Write-Host "Successfully set the default printer."
    Else
    Write-Warning "Cannot find the specified printer."
  3. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I did this at work this week as part of an installer, I used:
    (New-Object -ComObject WScript.Network).SetDefaultPrinter('PRINTER NAME IN HERE')
    Is running as a task an option for you? Maybe triggered from an event log entry for a change of default printer? I'm not sure if there is a logging option for default printer changes mind so just a thought.
    Just wondering, this PC at work isn't Windows 10 is it?
    The Windows 10 option to manage default printer has just been disabled globally at my place as it was causing issues where we install things such as PDF viewers etc stealing being the default and we like the mono printers to be default :)
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Doesn't Windows 10 also have an option where it automatically changes the default printer to the last printer used? IIRC, this is turned on by default (it's in Settings->Devices->Let Windows manage my default printer)
  5. RedFlames
    23 Apr 2009
    yes it does... in Settings > Devices > Printers & Scanners
  6. Flibblebot
    19 Apr 2005
    Most. Annoying. Setting.
  7. noizdaemon666
    15 Jun 2010
    It is a Windows 10 PC so I'll have a scout about and see what's what. Cheers chaps :)
