Build Advice £400 Gaming Pc!
Discussion in 'Hardware' started by legendzarr, 5 Apr 2012.
  1. legendzarr
    legendzarr What's a Dremel?
    30 Dec 2011
    Hey guys! Just wanted some help with a new pc im planning, mainly for skyrim on ultra! Any help would be great!
    Budget:£400
    Main uses of intended build:
    Gaming
    Parts required:
    Everything except mice and keyboard (including monitor)
    Monitor resolution:
    1280x720
    Storage requirements:
    Not to much, ill buy more when the prices go back to normal!
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers):
    Quite a few usb ports, no sli or xfire, dont mind about anything else
    Extra information about desired system:
    Be able to play skyrim at a consistent 30fps minimum
    Thanks in advance! And thanks to javaman for the template!
  2. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    hmmm skrim on ultra at 1080p, including a monitor for less than £400?
    not going to happen.
    but in the chance it does, il post here as i want to witness the fellow who manages to construct such a system for the op
    as for my constructive addition to the thread other than telling you it wont happen in that price range,
    id say if you want to oc as well, you are looking at a minimum of £550. closer to 600. a monitor will set you back at least £100 then you need a card which will max skrim. and a board which will hold a good oc
    the 2500k is a given. (£160) its great for games and you want to overclock. then try something like a p8p67 pro from asus (£110), then 8gb corsair vengeance (£45), a decent cooler (£30), a hdd (£45)
    ^ thats £390 there, excluding the screen
    as for graphics card? hmmm. personally, i dont know when the other cards from nvidia are coming, but id wait for them. otherwise, perhaps something like a 6950? or maybe a 6870, but i dont know if thatl max skyrim. im not familiar with 1080p
    then you have a case, approx £90 etc
  3. legendzarr
    30 Dec 2011
    Hmm, whatdo you think i should do too put the cost down then?
  4. j4mi3
    28 Jun 2011
    well, i think its the fact you need a monitor, (and trust me you dont want to skimp on a monitor, you want to pay at least £100 for a 1080p one), and the fact you want to max skyrim on it. The overclocking isnt that big of a deal although it does contribute to the overall cost.
    If i were you id present myself with a few options and pick from them:
    1)dig a little deeper into your pockets and up your budget by a couple hundred, telling yourself it will be worth it in the long run
    2) stay with what you have for now, buy the main parts of your new rig, and save until you can afford the remainder - basically dont buy a half assed system because you dont have the cash at the minute, theres no rush! If you have pc building fever, then do this. you will have fun building it you just can use it yet, then in a few months you might have more money to buy the rest!
    I mean, even if you went amd cpu, and got a slightly worse gfx card, you wouldnt be saving any significant sum of money.
    if your budget is set in stone, im afraid you can only wait and save up, or get a pc (and monitor) you might be dissapointed with. so id advise you to buy some good parts now until you have maxed your budget then wait until you can afford the rest.
    do you really not have any monitor around the house you could use in the meantime? it will only be temporary after all
  5. legendzarr
    30 Dec 2011
    Well, ok,thanks a lot for the help!
  6. j4mi3
    28 Jun 2011
    no worries, as i say, £600 would be a good place to start if you want a monitor as well.
  7. Nazata
    Nazata What's a Dremel?
    2 Sep 2011
    j4mi3 certainly knows what he's talking about, saving a bit more will definitely be worth it.
    Adding the cost of PSU, monitor and GPU to j4mi3's estimate would probably bring it over 600 (if good quality parts are used) but dropping to 4gb of ram would have little to know effect if you really want to save. Gelid Tranquillo (CPU cooler) is around £25, sometimes less also.
    And don't forget Scan's Today Only page, can easily cut £20-40 off a build when the deals are good.
    It might seem irritating right now, but trust me, when you look at a new monitor playing Skyrim on top settings at 1080p, you'll know you've made the right choice.
  8. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    Have you read the April Issue of Custom PC? System on there for £350 without a moniotor that can play Skyrim on max settings
  9. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    Pretty tight budget to include a monitor, I'd get a decent monitor and accept turning down the graphics for now, then upgrade later.
    Gpu will have the most effect but will also be the first thing that needs upgrading. Buy your speakers monitor psu and maybe case to last, the rest of it will be obsolete much quicker
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    As others have said, you need to up your budget. I put two builds together on Scan. The Intel one would be able to max it at 720p (as in OP) but does not include a monitor. The AMD one includes a good monitor (1080P) but would not be able to max every setting out.
    Intel
    AMD (FM1)
    Both are over budget but are the absolute lowest I would go really. The Intel one would also go very well at 1080p but probably not maxing it out. You can make it cheaper by getting 20 posts on here then you qualify for free delivery from Scan. And also don't get Scansure protection.
    N.B. Neither build includes Windows.
  11. Jipa
    5 Feb 2004
    Second hand GPU is what you really need! Get a bargain on a proper graphics card and see what you can do with the rest of the cash.
    Overall if you want to get something on a budget I always look for second hand buys, but the GPU's is really where it's at. Last gen card consume more power, but will still out-perform new cards at the same price bracket...
  12. j4mi3
    28 Jun 2011
    wait WHAT?
    i get free scan delivery? duudddddeee i have been paying all this time. how do i get it free?
  13. noizdaemon666
    15 Jun 2010
  14. j4mi3
    28 Jun 2011
    done, cheers
  15. legendzarr
    30 Dec 2011
    Thanks alot for all the help guys! Im going to see if i can raise the budget, i guess its always worth the wait!
