Windows Overclocking Tools
Discussion in 'Software' started by Randomeclipse, 6 Jul 2011.
  1. Randomeclipse
    Randomeclipse Minimodder
    11 Jan 2011
    Hey Guys/Gals,
    I know there's Prime95 for when you want to overclock, but does anyone mind listing the other tools to assist in a successful overclock?
    I did :search: but couldn't find a definitive list so to speak.
  2. adam_bagpuss
    24 Apr 2009
    Coretemp = check CPU temps
    CPU-Z = confirm ghz and RAM timings speed etc
    furmark = stressing GPU
    GPU-z = checking GPU clocks and Volts
    Benchmark suites such as custom PC one or 1 of the thousands out there (need to make sure what your doing is increasing performance lol)
  3. Randomeclipse
    11 Jan 2011
    Thanks, adam.
    I assume these tools are all freeware?
  4. adam_bagpuss
    24 Apr 2009
    indeed they are
  5. Randomeclipse
    11 Jan 2011
    That is most excellent news :)
  6. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    OCCT is good for a quick 1 hour check. Has some nice features.
    And is free btw.
  7. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    dont forget intel burn test, the official CPU stress tester designed by intel (also free).
  8. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    Subscribe to Custompc magazine your be an overclocking master soon enough. :)
  9. Randomeclipse
    11 Jan 2011
    Funny you should say that, as I'm waiting for my first issue and free gift to arrive now :). Although not sure why it takes 3 months to receive my first issue though....
  10. lp rob1
    lp rob1 Modder
    14 Jun 2010
    OCCT uses Linpack (the 'engine' of the Intel Burn Test) as one of its test. It also includes the same engine as CPU-Z and HWMonitor, meaning that it gives you all the stats you could possibly need.
  11. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Yeah OCCT is pretty complete. I usually prefer the Intel Burn Test over Prime95 though for CPU, it seems to be quite a bit more stressful and usually gets chips much, much hotter than Prime.
  12. Randomeclipse
    11 Jan 2011
    Hey guys,
    During the week I plan to have a stab at overclocking my 2500k using the BitTech guide. But I have just one question:
    Once I've followed the guide and carried out the bios changes, is it a case of then just stressing the CPU out with say Intel Burn and monitoring the temps with say Core Temp and hope they don't go past 70 degrees? (not sure of the magic figure tbh)?
    Cheers.
  13. Booga
    28 Sep 2009
    In a nut shell yes. Find out what the recomended temp figure is and run Prime 95, OCCT or another to stress the CPU.
    You are not just looking at temp though you want to see if your OC is stable and you don't get errors with the stress test.
  14. Randomeclipse
    11 Jan 2011
    Thanks, Booga.
    Would 70 degree C be the figure I don't want my CPU temps to surpass you think?
  15. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Mine does under load all the time. I always believed 80 was the thermal limit.
  16. Randomeclipse
    11 Jan 2011
    Ah right, thanks for that Warren.
    I ran Intel Burn and the temps didn't go above 51 degrees C so hopefully a 1ghz overclock shouldn't bump the temps up 30 degrees.
  17. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Everest or Aida64 as a general system monitoring program - I can't believe they haven't been mentioned. I have Everest feeding quite a bit of info to my alphacool LCD screen, which is invaluable when I'm doing fullscreen benching/gaming etc. and need to keep track of temps:
  18. OCJunkie
    19 Apr 2011
    Everest & Aida64 have everything, spec info, temp/usage monitoring, benches you name it, but as far as I remember the full packages aren't freeware.
