Hardware SSD Buyer's Guide
Discussion in 'Article Discussion' started by Claave, 8 Jul 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Altron
    Altron Minimodder
    12 Dec 2002
    First comment.
    Glad to see the corsair is "perfectly fins"
    :D
  3. Jim
    Jim Ineptimodder
    2 Sep 2007
    Good guide, very handy.
  4. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    Do'h Altron beat me to it!
    Good guide, will be taking notes.
  5. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Excellent and needed guide as so many people are still unfamiliar with SSD basics. Surprised not to see Intel's drives not getting any recommendations as they are buyers favourites.
  6. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    So, Corsair or Crucial, basically :) Nice to know, as I've been thinking about a small SSD for a while now.
  7. Baz
    Baz I work for Corsair
    13 Jan 2005
    OCZ too, but yep, in UK those three are the most reliable options for stock and decent pricing.
  8. Baz
    13 Jan 2005
    While there's nothing wrong with the Intel Drives (as stated in the article), bar slow sequential writes we feel there are better options elsewhere now. If you were to spot an Intel X25-M 80GB for £100 though, you'd snap it up no doubt.
  9. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Have an Intel 160Gb G2 on my notebook, and I don't think on replacing it for these faster drives. My notebook can't even push the SSD (I have an ICH8ME SB)... Anyway it's wayy better than a 2,5" HDD :)
    Maybe I'll buy one of these Corsair Force Series to my Q6600 and put my GsKill Falcon I in my server...
  10. mi1ez
    mi1ez Modder
    11 Jun 2009
    C300 looking very tempting. A little TOO tempting on my salary...
  11. Ph4ZeD
    22 Jul 2009
    The C300 is tempting me too. I'm finding squeezing my games on my 80GB Intel difficult, and £113 for a SSD with 355MB/s read speeds is hard to turn down. Problem is that my motherboard doesn't support SATA 3 :(
  12. Hereisphilly
    Hereisphilly What's a Dremel?
    8 Jul 2010
    That crucial is really tempting... especially since i have the Gigabyte x58A ud3r...
    Does anyone know if the 2 sata 6gbps ports on the board would be fine, or am i better off buying the expansion card as well?
  13. WarMadMax
    WarMadMax What's a Dremel?
    12 Dec 2006
    Nothing bad afaik from running on gigabytes sata3 ports, some numbers in crucial's forum.
    wasn't far off / the same as an add in card.
    I've ordered the add-in for my maximus formula, but i went with the 64gb C300 for now.
    first SSD and want to find my feet first.
  14. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    The expansion card will be worth it, we've played around with some of the built in SATA 6Gbps of various boards and they've not been so great
  15. borandi
    borandi What's a Dremel?
    27 Jan 2010
    Which SSD to buy? The OCZ RevoDrive.
  16. Hereisphilly
    8 Jul 2010
    Have you had a go with the said gigabyte board? Any idea at what performance drop i would be looking at (i.e. if its a few % i'll save my money)
    Cheers
  17. Baz
    13 Jan 2005
    I'll be looking at C300 performance with a variety of Mobo's soon hopefully. We were genuinely surprised to find plenty of boards which carried SATA 3 (6Gbps) ports just were not up to the task. Until now the highpoint is the only one we're confident can do the business.
  18. Hereisphilly
    8 Jul 2010
    Great, i'll look forward to that read, thanks!
  19. smc8788
    smc8788 Multimodder
    23 Apr 2009
  20. Ph4ZeD
    22 Jul 2009
    Could you link the highpoint on Scan?
Tags: Add Tags
