Case Mod - In Progress Project Indigo / Define R5 ( Completed )
Discussion in 'Project Logs' started by Icelander, 11 Mar 2015.
  1. Icelander
    Icelander Minimodder
    3 Mar 2015
    Hello everyone
    I present to you project INDIGO .
    Partially sponsored project. Mundi from Icemodz.com [​IMG]
    This will be a fully watercooled project using PET-G Tubes
    Im using AMD A8-7600 APU/Cpu quad core
    Gigabyte A88XM-D3H Motherboard
    Corsair Vengeance Pro DDR3 Ram 2133mhz
    PSU : will know shortly
    GPU : will know shortly. ( R9-280x )
    Case : Fractal Design Define R5 Modded
    Sleeved cables from Icemodz.com + LED's
    Fans : Corsair SP120 &AF-120
    This project is getting a paintjob, side and front changes with a Dremel and more.
    Final Pics on page 5
  2. Shirty
    18 Apr 1982
    Just use the tags either side of your image URLs, pictures are working perfectly well.
  3. Icelander
    3 Mar 2015
    Alright Here come the first photos of my build log. I started out putting window and spray painted fans and other things. Let the pictures speak for themselves...
  4. Shirty
    18 Apr 1982
    I've embedded your enormous Dropbox images in your post, however I'd recommend using a more suitable image host like Photobucket, Imgur or Flickr. Otherwise your thread will take ages to load and kill browsers :thumb:
  5. Icelander
    3 Mar 2015
    :duh:
  6. Icelander
    3 Mar 2015
    OK Will look into that Thanks
  7. Icelander
    3 Mar 2015
    Moderator can delete this post as I had issues with dropbox so I terminated them and don't use it anymore
  8. Icelander
    3 Mar 2015
  9. Icelander
    3 Mar 2015
    same
  10. Icelander
    3 Mar 2015
  11. Icelander
    3 Mar 2015
    more uploads coming soon
  12. Icelander
    3 Mar 2015
    [​IMG] [​IMG] And The Cpu is Ready [​IMG] [​IMG] Making a custom front panel using MDF into the hole [​IMG] [​IMG] Some cables sleeved from icemodz.com [​IMG] [​IMG] Need to paint the Bitspower Logo Golden inside to match the fittings [​IMG] [​IMG] [​IMG]
  13. Icelander
    3 Mar 2015
    Well I have Painted the Sidepanel Indigo<<=>> Metal Violet.
    Fittings and GPU are on the way so I will soon be able to tube up this Beast:
  14. Icelander
    3 Mar 2015
    [​IMG]This is not the placement for the Bitspower Logo but a handmage done with dremel and some paint.
    I will be using Bitspower Fittings, Reservoir and other components from them. They simply just have the best fittings available in my opinion :)
    [​IMG].
    And a Teaser for my next project I will be using this Motherboard :
    Have fun all, Modding your way. It is the only way :rock:
  15. Icelander
    3 Mar 2015
    Just a small update for you all. Only few days until I get my camera so bear with me here for the quality.
    I am redoing the paint job on the sidepanels and am using Metallic pearl flake VIOLET = Indigo blue.
    After that I will put three times of clearcoat for that extra oompfff.
    Oh yeah and I will give you a sample of Mayhems die :)
    here you can see the Pearl affect
    Only one drop of Mayhems Purple
    One drop of Mayhems ocean blue + Purple together
    To me it looks Indigo blue and that is not blue, and not purple but just in the middle or mixed together LOL
    Pics of the Die from Mayhems:
    Thats it for now.
    Thanks for stopping by
  16. Icelander
    3 Mar 2015
    Was painting but the spray can finished up so I have to go buy more.
    Also the smoked acrylic front cover doesn't arrive until monday.
  17. Icelander
    3 Mar 2015
    Not much going on other than more Paintjob...
    Catch u all Later...
    Thanks for coming by
  18. Icelander
    3 Mar 2015
    Hi everyone. Today is Good day like most are. For me specially because I got Things to show of and tell about.
    My sponsor Mundi @www.icemodz.com got me a Samsung camera for a price that is like he practically gave me the Cam so I can show off me modding in better quality.
    Secondly I bought more Plexi/ Extruded acrylic from 3mm to 6mm >> which is Smoked which I am putting on the front of the case. The clear one I have various sizes and thickness.
    I am going to make the window side Larger and in different shape, also the PSU cover is getting a makeup.
    Here are some Pics with my new Camera :rock:
    That is it for Now I start sawing,,, :)
    Thank you for coming :thumb:
  19. Icelander
    3 Mar 2015
    [​IMG]Did some cutting and filing.
    Going to file a bit more and sand + spreypaint the side
  20. Icelander
    3 Mar 2015
    :wallbash::wallbash: NOOOOOOOW I am MAD My 280x has died and I just bought it used from a guy two weeks ago. It can't be repaired :waah: I don't even own another GPU or a block :idea:
    I have spent so much on this project. Mainly WC stuff and more and I am not well funded so I do not know what now or when I can finish this.
    Most of the watercooling stuff is in post as I speak...
