Scratch Build – In Progress Project Buyangyang
Discussion in 'Project Logs' started by Arcis Modz, 15 Jun 2015.
  1. Arcis Modz
    Arcis Modz What's a Dremel?
    31 May 2015
    PROJECT BUYANGYANG
    Modder: Andrew Lee(Andrew Lee Adanza)
    FB: https://www.facebook.com/andrewleekho
    Intoduction
    The aim of this build is to showcase all components of a computer.
    As you can see, all parts are exposed. Even the Liquid Cooling System.
    Thank you to the following sponsors for supporting this project.
    Thermaltake Technology Inc
    Thermaltake Philippines
    MSI Philippines
    MSI Global
    Plextor Philippines
    Table of Contents
  2. Arcis Modz
    31 May 2015
    Hardware List and Photos
    SPECS:
    CPU: I5 4690K - ✓ (temporary procie, waiting for the 4790K)
    MoBo: MSI Z97 XPower AC - ✓
    RAM: undecided -
    GPU: MSI GTX 960 Gaming 100ME - ✓
    HDD: -
    SSD: Plextor M6S 128gb - ✓
    PSU: Thermaltake PSU -
    LIQUID COOLING:
    CPU Block: Thermaltake Pacific W2 CPU Water Block -
    GPU Block: -
    Rad: Thermaltake Pacific RL280 Radiator -
    Pump: Thermaltake Pacific P1 Black D5 Pump w/ Silent Kit -
    Reservoir: Thermaltake Custom res or Pacific T11 Reservoir -
    Stop Plug - Thermaltake Pacific G1/4 Stop Plug w/ O-Ring – Black
    Extenders:
    Thermaltake Pacific G1/4 Male to Male 30mm Extender – Black
    Thermaltake Pacific G1/4 Male to Male 20mm Extender – Black
    Thermaltake Pacific G1/4 Female to Female 30mm Extender – Black
    Thermaltake Pacific G1/4 Female to Female 20mm Extender – Black
    Adapter:
    Thermaltake Pacific G1/4 90 Degree Adapter – Black
    Thermaltake Pacific G1/4 45 Degree Adapter – Black
    Thermaltake Pacific G1/4 Y Adapter – Black
    Fittings:
    Thermaltake Pacific G1/4 PETG Tube 5/8” (16mm) OD Fittings – Black
    Tube: Thermaltake V-Tubler PETG Tube -
    Coolant: Mayhem UV Green-Yellow Dye/Mayhem Yellow Dye (custom color) -
    MODS and MISC:
    Fans 1: Thermaltake Riing 14 High Static Pressure LED Radiator Fan -
    Led Lights: Custom LED Strips(white) -
    PHOTOS
  3. Arcis Modz
    31 May 2015
    Sketchup/Plan
  4. Arcis Modz
    31 May 2015
    TOOLS and ACCESSORIES
  5. Arcis Modz
    31 May 2015
    MATERIALS
  6. Arcis Modz
    31 May 2015
    MOD ON
  7. Arcis Modz
    31 May 2015
  8. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    Looking like a good project man. Like the layers involved in case!
    How's that scroll saw if I can ask. Thinking about the same one from my local shop, is it loud?
  9. Arcis Modz
    31 May 2015
    Thanks man. glad you like it. :clap:
    for the scrolls saw, if you use the proper blade, for me, the noise is still tolerable. but if you try to cut metal sheets, you can imagine how noisy it is. :wallbash: also, same goes for aluminum L bar/angle bar. at first its noisy but when the blade is in, the noise is tolerable. :) hope this helps you decide. but i can say, it sure is a lot of help on working on small things if you don't have a laser/cnc.
  10. hovek
    23 Jan 2014
    Thanks for the answer man. Yeah, I live in an apartment that's why the question. I'll search for some good quality blades then so.
  11. Bygone
    Bygone Minimodder
    15 Apr 2015
    I like your design, but have you considered the issue of dust in your system, with it being as open as it is?
  12. Arcis Modz
    31 May 2015
    just use the correct blades on certain materials, i think you will be fine. :)
    thanks bro. the purpose of the case is for showcasing computer components. it will not be my daily case. it will only be used for rigshows/events.
  13. Arcis Modz
    31 May 2015
  14. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    I've already seen such a design but anyway I like to see the way your case is "growing up" :)
  15. Arcis Modz
    31 May 2015
    yeah... idea is from h frame and level 10. :D :)
    thanks a lot. :)
  16. Arcis Modz
    31 May 2015
  17. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Hi,
    Awesome project, i really like the way you put elements ans the design...
    Following you,:hip:
  18. Arcis Modz
    31 May 2015
    Hi Canard,
    Thanks mate.
  19. Arcis Modz
    31 May 2015
  20. storm-83
    storm-83 Minimodder
    7 Nov 2014
    This turned out great!
