System Tray v SMP Client
Discussion in 'bit-tech Folding Team' started by Votick, 18 Jun 2009.
  1. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    I have a AMD 4800+ 2.59ghz dual core processor.
    Its running the single tray client at the moment.
    Is there an advantage of runing the SMP client?
    Both core's seem to be 100% full load all ready with the system tray.
    noobie question :p sorry :)
  2. saspro
    saspro IT monkey
    23 Apr 2009
    SMP will give more points. Any GPU's running on that rig?
  3. Votick
    21 May 2009
    Nope just the CPU.
    Which SMP client do i use there are two
    Its a Windows Vista Ultimate 64bit with 4GB ram.
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Either MPICH or you could try the VMWARE version
  5. Votick
    21 May 2009
    Haven't had much luck with VMware
    So I will try the MPICH
  6. Votick
    21 May 2009
    I enter my computer account name and pasword on the install.bat
    it encrycpts it to the registery and then can't connect to a socket?
    somthing about ports?
    im sure this is why i gave up last time
  7. Votick
    21 May 2009
    hmm may have a fix :)
    EDIT: Nope :( don't have a clue
  8. Votick
    21 May 2009
  9. saspro
    saspro IT monkey
    23 Apr 2009
    Is UAC turned off?
    Do you have a password on the PC?
    Try an uninstall & reboot then reinstall.
    Usually it's caused by a lack of .net 2 but Vista should have it installed already.
  10. Votick
    21 May 2009
    It dose have it already installed
    thats the first thing i checked :)
    I'll take UAC off and uninstall reboot and install again like you said
    Yes there is a password for the pc, and i did enter it in for the install.bat
  11. Votick
    21 May 2009
    Took UAC off and teh PC needed to reboot.
    Ran it again and it worked.
    Thanks saspro :):clap::clap:
  12. Votick
    21 May 2009
    Quick question
    was % of usage is the default set to?
    how do i go about setting it to 100%?
    coolings fine so not an issue :)
    120mm Coolermaster Hyper TX :) heh
  13. saspro
    saspro IT monkey
    23 Apr 2009
    By default it's 100%, did you remember to create a shortcut to the .exe with -smp in the target?
  14. Votick
    21 May 2009
    nope
    ill do that now.
    so what will teh target look like with the -smp on?
    Im trying to add it but it won't let me :(
  15. Votick
    21 May 2009
  16. IwantAbetterPC
    IwantAbetterPC What's a Dremel?
    27 Apr 2009
    Mate,
    Search the folding forum here for "Notfred", and you should get about 5 hits. In the bottom one, there is a link from Saspro to a VMWare guide for setting up VMWare clients - it is a piece of piss (I'm picking up on Saspro's technical jargon now!) to install and configure - I was worried that I knew nothing about Linux so wouldn't be able to work the VMs, but the guy who wrote the Notfred client has made it all self-contained, so you need zero Linux skill to run this. If you have Virtualisation enabled in your Bios, the VM will detect it is a 64 bit setup and start two Linux SMP clients automatically, doubling your points compared to a windows only smp client. It is no harder to set up than a normal Stanford client (your woes with windows SMP aside!) I did it on my dual Xeon Dell, but it doesn't support 64bit, so wouldn't start the SMP clients - but it was smart enough to start 4 normal clients for me instead!
    Edit: found the VMWare guide link - http://www.maximumpc.com/forums/viewtopic.php?t=92133 provided by Saspro
    Give it a try!
    Craig...
  17. Votick
    21 May 2009
    I'll try it.
    I installed VMWare before but couldnt get the dam thing to run :)
    plus this windows SMP is doing nothing lol
    3 hours and notjing has been done lol
  18. saspro
    saspro IT monkey
    23 Apr 2009
    Logfile?
  19. Votick
    21 May 2009
  20. Votick
    21 May 2009
    lol how can i get 1% done 3 times?
