Other ---
Discussion in 'Software' started by MarkW7, 7 May 2009.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Post removed by user.
  2. Krikkit
    21 Jan 2003
    Corsair bundled an encryption program with my pendrive, that did exactly that.
  3. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Do you know if it's avaliable for free download :D
  4. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Mark, are you running Windows 7, I remember you talking about it? If you are, Bitlocker to Go should work, I haven't tried it out yet.
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Hey, Turbotab
    It will be used on multiple OS's. Windows and Linux.
  6. Turbotab
    4 Feb 2009
    TrueCrypt is a popular app and its free, it also works on various formats.
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
  8. Krikkit
    21 Jan 2003
    Why don't you just try it? It's free. :p
  9. Akava
    Akava Lurking...
    28 Jul 2007
    TrueCrypt is a brilliant encyrption program with loads of features, including the ability to hide a portion of data inside another area, so even if you have to give up your main password, you can have other more sensitive data hidden deeper.
    Give it a look...
  10. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    TrueCrypt requires administrator privileges to run a drive.
  11. barack
    barack What's a Dremel?
    11 May 2009
    i also use truecrypt, its very fast & reliable software to use.
  12. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Any other ideas?
  13. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    do they have winrar installed up on your school computers.. just set a password and rar up your files, set to encrypt the filenames
  14. yodasarmpit
    yodasarmpit Modder
    27 May 2002
  15. thehippoz
    19 Dec 2008
    cool deal.. waiting for barack to come in and recommend this now XD
  16. Turbotab
    4 Feb 2009
    Presidential approval :)
  17. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    I actually think the WinRAR's the best idea yet; pretty much everything runs WinRAR and it is pretty much impossible to attack by any means other than brute force (I should know, I had Elcomsoft's WinRAR cracker; it would take days of full-out blasting to break even a moderate password, since mine were about 180 characters you'd need a Cray to break them). Plus you can encode the files seperately so you don't have to decode everything to get what you want. Keep it simple etc
  18. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
  19. Krikkit
    21 Jan 2003
    WinRAR unplugged Cheesecake.
  20. marchelyx
    marchelyx What's a Dremel?
    6 Jun 2009
    How do I retrieve data from a broken pen drive? I broke a pen drive accidentaly. It broke into two parts at the base of the USB port. Is there any way to retrive data stored in the drive?
    ___________________
    market samurai ~ marketsamurai ~ marketsamurai.com
