Modding What tap size will I need for motherboard standoffs?
Discussion in 'Modding' started by Parge, 16 Jan 2013.
  1. Parge
    16 Jul 2010
    As per the above, I'm planning on tapping some motherboard standoff holes into a piece of 6mm acrylic.
    What size tap will I need to use?
  2. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    M3 or think its 11/32 unf
  3. Guest-23315
    Guest-23315 Guest
    ^^ Depends what threads are on the standoffs...
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    My bad its 6/32 UNC no 11/32 UNF
  5. Parge
    16 Jul 2010
    Jeeze. Taps are expensive. I might just use a nut and bolt.
  6. Parge
    16 Jul 2010
    Does anyone know if this kit would work?
  7. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    6/32 unc tap
    M3
    tap wrench / spanner at bottom of page.
    If you go for the sets of taper second and bottom can be expensive but in plastic and ally change of breaking are very low if your slow and gentle but works out about £35 for m3 , 6/32 and a spanner
    If you wont to cut costs just use a second or a taper for about £7 as the thread will set in it fine work out about £20 for m3 , 6/32 and a spanner
  8. Cheapskate
    13 May 2007
    Through bolts+ bic pen section standoffs.:thumb:
    If you really want to tap, I'd recommend getting something decent with a corresponding drill bit. I've never had the smaller, cheap, Chinese made taps to work right.
