Displays Ok Am ready to order a new 24" Monitor . .
Discussion in 'Hardware' started by BradShort, 28 Aug 2014.
  1. BradShort
    BradShort Familyman - Forever gamer
    23 Apr 2009
    SO I'm ready for a new monitor. got a HD 7950, i5 2500K @4Ghz and playing FPS, ELITE, and Fifa mainly.
    Looking at a 24" monitor as needs to fit under a shelf and have sort of decided on AOC G2460PQU
    http://www.amazon.co.uk/AOC-G2460PQU-Widescreen-Multimedia-Kensington/dp/B00C144AYK
    Need Height adjustment or under 41cm height and Budget up to £200
    Have I chosen well, or should I consider anything else? Cheaper would be good :):thumb:
    Thanks in advance.
  2. Mr Happy
    Mr Happy 4 8 15 16 23 42
    25 Apr 2009
    Have a look at this one Here
    You also get free delivery through Scan if you register on the Scan section on this site
    Here
    BradShort likes this.
  3. GeorgeK
    18 Sep 2010
    I'd go for a Dell IPS too - it's only 60Hz but, unless you're obsessed by higher frame rates, then you'll benefit massively by the more beautiful colours :thumb:
  4. BradShort
    23 Apr 2009
    That was my other choice!! But I have been swayed by the 144Hz arguments!
  5. Teelzebub
    27 Nov 2009
  6. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    +1 ^
  7. BradShort
    23 Apr 2009
    So do I go sexy monitor or the 16:10 arrangement . . . Its a tough job this choosing monitor business!
  8. BradShort
    23 Apr 2009
    ordered the Dell H guys, Thanks :)
  9. Mr Happy
    25 Apr 2009
