News Rumour: AMD and Nvidia slash 40nm chip orders
Discussion in 'Article Discussion' started by Sifter3000, 19 Feb 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. lewchenko
    lewchenko Minimodder
    17 Dec 2007
    'Silicon' isnt recession proof, especially when chip companies like NVidia, Intel, AMD make most of their money from the highest margin products. (ie.. the not so cheap ones to you and me).
    The biggest worry must be that innovation will slow down (why spend x billion dollars making something new ... assuming you can get that kind of finance these days ... if you can't sell it ?). Conversely, we must innovate to create new revenue channels in order to get us out of recession !!!
  3. Jojii
    Jojii hardware freak
    12 Dec 2007
    I apoligise for not having a referance, but i read someplace that the TSMC 40 nm process was leaky and not really generating the performance improvements usually associated with a die shrink just the cost savings. Now i'm just guessing but maybe there is some hardball being played in order for ati and nvidia to get further price cuts so they can fatten thier pockets and/or produce value "mainstream" cards that have similar performance to todays higher mainstream segment.
  4. UrbanMarine
    UrbanMarine Government Prostitute
    7 Aug 2008
    I understand you have to keep things going but why all these different versions? 2 cards per series per company is more than enough. ex. There is 140+ variations of 9 series cards in the market with 9 types (9400GT-9800GX2) in the series. Overkill in a weak economy. The same goes for CPUs and their overflow (2.0ghz, 2.1ghz, 2.2ghz, 2.5ghz etc).
  5. Goty
    Goty Minimodder
    13 Dec 2005
    If I'm not mistaken, video card makers make most of their money in the entry and mainstream markets. The margins are smaller, but the difference is far offset by the volume of the cards sold.
  6. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    Damn. I am wanting 40nm GPU's to be out (and realistically priced) when I purchase my new PC by the end of the year....
  7. Sebbo
    Sebbo What's a Dremel?
    28 May 2006
    i heard the same thing from the INQ, here's the link: http://www.theinquirer.net/inquirer/news/878/1050878/tsmc-40nm-revealed
    also, much of the drops in process size have been around the 10nm mark (65 to 55, 55 to 45), so a drop of 5nm is likely to not hold that much of an advantage over 45, and so apart from some enthusiast parts, most companies will likely wait for a stable 32nm process (as Intel has done, going from 45nm straight down to 32nm)
  8. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    65 > 55 > 45 > 32
    what is wrong above, is 35 not good?
  9. alwayssts
    alwayssts What's a Dremel?
    20 Feb 2009
    It's actually like this:
    90>65>40>28. Those are the "full" nodes.
    80>55>32 are the half nodes...aka "dumb" transistor shrinks that don't require a redesign of the chip for the new process.
    You can figure the next full node is ~70% of the transistor size of the previous node, and half nodes 85%. '5's' have nothing to do with it.
    ex: a 40nm product could be shrank to 32nm in the same way 65nm was shrank to 55nm (ex: GTX280->GTX285) without being redrafted. A 65/55nm part on 40nm would, however (ex: R600 on 80nm to Rv670 on 55nm.). This is why we are likely to see GT300 on 40nm (by then a "known" process) and a 'easy' dumb shrink to 32nm later, as this is what nvidia is known for. From my understanding though, 28nm will VERY CLOSELY follow 32nm (Q4 - 32nm, Q1 2010 - 28nm), and this is IMHO what we should expect ATi's post Rv870 chips on, as they are known to quickly adopt new processes even if requiring a redesign, and play it less safe than nvidia (although sometimes that bites them in the ass.)
    To further cement this theory, figure Rv870 is approx. the size of Rv670-Rv770 on 40nm, ~200mm2. This product shrank to 28nm would be approximately the size of Rv730/Rv740. Coincidence? I think not. Notice how Rv730 is similar to Rv670, and rv740 to rv770 (although units are dropped because rv770 was on 55nm, not 65nm). Expect this trend to continue, with each full node ATi's high-end chip dropping to mid-range with half the bus size. This is how ATi now designs their chips; with the future in mind and a 'trickle-down' effect. My theory is they shoot for a roughly 15x15-16x16mm chip (196-225mm2), the smallest a 256-bit chip could be, knowing that the next node will be ~70% of that, equalling a chip roughly 140-150mm2, perfect for midrange.
    Hopefully that answers your question, and didn't put you to sleep. :)
