Other How would you tackle this roundabout?
Discussion in 'General' started by lancer778544, 7 Oct 2014.
  1. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    This has raised quite the discussion in work and I'd like to ask the B-T hivemind to see what they think. This is the roundabout in question with the route you want to take:
    The first two exits on the roundabout go nowhere basically and the majority of traffic will be going the same route as you. As you can see, there are two unmarked lanes entering the roundabout but there is only one on the exit. Which lane would you take?
    I would pick lane two personally as it's past 12 o' clock but my coworker who is a local would pick lane 1 as to him, the sign shows the exit as coming straight off the top of the roundabout so it classed as straight ahead.
    I would put up a poll but I don't know how...
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    It should be lane 2 as the exit is more than half way round the roundabout (as is indicated on the road sign)
    Lane 1 is for the road that is straight ahead, and what looks like a site entrance to the left.
    As for your coworker, he's likely to get his nose cut off driving like that.
  3. asura
    asura jack of all trades
    22 Apr 2009
    Not sure how correct it is, but my instructor taught me that anything after the second exit was technically a right hand turn and so you signalled as such... though the government seems to disagree; however, the route you show is definitely an exit to the right despite the fact you're technally staying on the same road. But that's just my opinion, and I could be wrong...
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I think you can go in Lane 1 or Lane 2? - the line is thick for the entry and exit on the roundabout, I thought that meant two lanes on and off?
    Though - if I was driving at it, I would go into 2.
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
  6. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Lane number the second.
  7. wyx087
    15 Aug 2007
    Driving in greater London have taught me how most drivers in this area sees it: there's no correct lane only the lane with less cars!
    Although the exit only have 1 lane and right of way isn't clear, this seems to be quite common at most London junctions. It is a bottleneck but traffic flows fine over here.
    Personally, the first time I approach OP's roundabout, I'd take lane 2 because you are going more than 180 degrees around the roundabout. But after awhile if I see most cars take lane 1, then I'll go with majority.
  8. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Speak to your council's traffic or road department, they're pretty public facing so should talk it over with you.
    If you raise the issue, they may even paint some arrows.
    But yeah, I'd take lane 2.
  9. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    If both lanes had traffic lined up, I'd pick the lane that has the shortest queue. If the round about was empty then I'd choose the quickest line being lane 2. I'm an impatient driver, every car in front of me just annoys me... no matter what they do.
  10. jinq-sea
    15 Oct 2012
    What it is right, is the right lane innit butt - I means, lane number two!
    /southwales /morespecificallynewport
    I miss living in S. Wales!
  11. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    How fast am I going???
    :D
  12. GaryP
    GaryP RIP Tel
    31 Aug 2009
    2. Everyone else is in 1 is wrong.
    Unless queue is shorter or there is some dithering ***** in two.
  13. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Lane 2 is a safe bet.
  14. David
    7 Apr 2009
    This.
  15. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Depends on the weight of traffic when approaching the roundabout, both lanes are acceptable/legal (afaik) but my preference would be lane 1 going on the signage.
    Mainly because (to me) the signage indicates the exit before the one i want to take is a minor road so it would be unlikely many people would be taking that exit, meaning i would have to filter into a busy left hand lane after the first exit and before the next.
    To me it seems like the road layout could do with improving, if as you say the main exit is a single lane they are forcing drivers to filter down from two lane into one on a roundabout, there should really be two lanes at the exit, even if it was only for a few hundred yards.
  16. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    I have something similar where I live.
    For me, its simple, as a BMW driver I basically get into the shortest lane - regardless of my intended direction of travel.
    However, when I owned my Audi, I would have always chosen lane 2, there is always that small risk, if you took lane 1, the guy or gal next door wishes to that the second exit, just as your passing it and boom.
    But as I said, I don't drive and Audi anymore, so I refer back to my original sentence!.
  17. Nexxo
    23 Oct 2001
    Like a boss.
  18. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    Lane 2 - It's safer in that circumstance (there is a similar roundabout near me). If you get a moron in lane 1 cutting you up, you can easily compensate whilst in lane 2 by going around the roundabout and trying again.
    If you did drive it in lane 1, and you cut someone up, there would be less options available to prevent you from hitting the (rightous) driver in lane 2.
    Also, as with others here, I was taught that past 12 o'clock would mean it's a right turn and to use the right lane unless otherwise instructed (by road markings ETC)
  19. Mister_Tad
    27 Dec 2002
    As the driver of an impractically large car, I'd take both lanes in, out and throughout the roundabout.
    If I was driving a more sensible car, I'd take two out of safety, banking on a jackass in nailing it through in lane 2 going "straight". As others have said , I believe the sign indicates that both lanes are valid to the stated destination - 1 for exiting prior to that, 2 for exiting after that.
  20. theshadow2001
    3 May 2012
    This
    And its amazing the amount of people that don't know this.
