Windows Skinning question
Discussion in 'General' started by Crazith, 3 Jan 2004.
  1. Crazith
    Crazith What's a Dremel?
    6 Jun 2003
    well I wanted to make this a poll
    but I have searched the forums and didn't find any reasonable answer to what I am looking for.
    I downloaded Litestep, Windowsblinds, and DesktopX. I am wondering what everybody actually uses and likes. I would like to know some of the personal opinions before I actually install one of them.
    aditionally I want to know any of the bad sides to each program so I have a way to judge it.
    I am on a W2K Pro and the hidden theme section in it doesn't suit my needs and also I don't think the theme hack in XP would work
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    disregard this post....
  3. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    ok
    Windowblinds is actually pretty good... it's come a long way - I remember it being a bit of a hog but it seems pretty smoothly done now.
    I'd recommend trying it out.
  4. Crazith
    6 Jun 2003
    so what version was the one you used?
  5. El Nosba
    El Nosba What's a Dremel?
    22 Sep 2003
    i use windowsblinds 4
    with the longhorn slate 4051 theme to it
    my opinions on it ? It was well worth the dl time ( few seconds, :) )
    if i could have a default skin of windows, itd be the one i have now
    as for bugs/glitches, well ive only seen 2 with the theme i have
    1: sometimes the start button disappear ( the actual button, not the whole taskbar, or its use, its just a matter of click in the spot where it is / was if you wanna say it like that, and itll pop up again )
    2: sometimes wen installing programs, the ok/cancel buttons they have there are like this
    Code:
    ---Ca----
    |  ncel  |
    its still readable, and its just anoying wen you install stuff ( even tho its obvious wat the buttons are, cause there always in the same place )
    ___________________________
    Even with the bugs... ( each theme has its own bugs, obviously ) i still would make this my default skin if i didnt have windowblinds
  6. Melov
    Melov What's a Dremel?
    30 Apr 2003
    Personally I like StyleXP. Not sure if it works with Wink2
  7. tk421
    tk421 Idiot.
    15 Jan 2002
  8. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    No it won't work, as StyleXP is just a hack on the built in theming that's in XP and 2k3 that lets you use unsigned themes.
  9. pranks7er
    pranks7er mange tout
    25 Dec 2002
    desktopx i found hard to config, im using the one that your edit the utxtheme.dll (i used the autopatcher)
  10. Fatboy
    Fatboy Bored
    8 Oct 2001
    i changed my uxtheme.dll and just apply the skins through teh desktop properties thing. Easy , and doesnt require me to use extra annoying progs, or cracked progs :grr: :eyebrow:
  11. Crazith
    6 Jun 2003
    I'll quote myself but I have Windows 2000 Professional so I can not do that dll
