Just Curious
Discussion in 'bit-tech Folding Team' started by ThunderBob, 12 Aug 2009.
  1. ThunderBob
    ThunderBob What's a Dremel?
    19 Sep 2005
    GTX260+Q6600.
    GPU+VMWare SMP(2cores)
    GPU+VMWare SMP(2cores)+VMWare SMP(2cores)
    What would give the best PPD?
    With 2 SMPs running the GPU drops a lot.......
  2. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    How are you setting the priorities? You need to make sure that the GPU client is slightly higher than the SMP, then your GPU will go back to its maximum points, and the VMware will be very slightly below the maximum. Plenty of threads on the board about this. :search:
  3. Unicorn
    25 Jul 2006
    Yeah as CNL says when running VMware SMP clients you need to set the priorities correctly otherwise you end up starving the GPU of CPU resources and its PPD drops like a stone.
  4. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    the suggestion has been to use
    PriFinitty
    there is a few guides floating around on the forum on how to set it up
  5. Vince_Kinslow
    Vince_Kinslow Folding Millionaire
    25 Apr 2009
    Why are they not stickied then? :nono:
  6. Unicorn
    25 Jul 2006
    Nothing is ever stickied in the folding forum!! I have asked for several to be but the mods seem to just ignore us :(
    Where's the love?
  7. saspro
    saspro IT monkey
    23 Apr 2009
    saspro for mod
    Vote here
  8. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    I don't remember receiving any PMs from you about stickying particular threads, so if there's something you would like, just let me know.
