hi, i have a basic system running an amd a8 6600k and was wondering on suggestions on what motherboard to upgrade to ( have a vantage case and corsiar psu if that helps) thanks in advance
Graphics are handled by the APU, motherboard wont change graphics performance. Could add a graphics card to your set up if that's where you want performance gains.
I've not looked at AMD boards for a long while, but this was the first one I found on scan with USB3 that should fit your CPU. Or you could just buy a USB3 addin card like this, which will solve your problem without spending as much. If you just want your computer to be 'better', save up and buy a whole new CPU+mobo+graphics card, you'll thank yourself later.
