Case Mod - In Progress M3- SFF
Discussion in 'Project Logs' started by PcJunkie209, 3 Aug 2012.
  1. PcJunkie209
    PcJunkie209 What's a Dremel?
    3 Sep 2011
    Ok here's a mod I did for Gigabyte for their GESL event in Pomona, CA. I used a Silverstone SG01-Evolution case. The idea was to watercool the CPU because we all know that Ivy runs a little warmer than Sandy. :) So I didn't Want any heat issues down the road. Upon request from GBT I decided to try having the case airbrushed with digital camo. Its been awhile since I posted any worklogs and its about time I get caught up. So this is one of many to come. Enjoy and thanks for looking.
    So on with the parts!
    Specs -
    Intel i7 3770k
    Gigabyte Z77 Sniper M3
    Gigabyte GTX680
    Silverstone SFX450 PSU sleeved with MDPC green, tan and black
    Patriot Pyro SE SSD 120gb x 2 in Raid 0
    Patriot Division 2 Viper Extreme 2400mhz 16gb
    cooling parts -
    Koolance CPU-370SI Water Block
    Koolance PMP-400 Pump
    Koolance Pump Nozzle & Reservoir Base for PMP-400
    Koolance Misc. angles fittings
    FrozenQ FlexTank res.
    Monsoon Black compression fittings
    Masterkleer 1/2in clear tubing
    Mayhems Aurora Extinction Green liquid
    Black Ice 160mm Radiator
    Enermax White Clutster 80mm fans x 5
    Pics coming soon.
  2. PcJunkie209
    3 Sep 2011
    Ok so here's some pics peeps!!
    This is the SG01-Evolution case
    Ok so I'm gonna be changing a few things and taking things out like 5.25 bay and HD cage. Here I changed the feet out for the MNPCTECH billet aluminium feet.
    I'll also be adding another 80mm fan for better airflow in case above GPU. Here I proceded to hand drill out some holes to match left and right side. SO MUCH FUN!!! :) Then I drilled another 80mm fan hole.
    Finished all those holes..... Yay!!
    With the front removed you can see the piece of mirror acrylic that I decided to cut away some of it so I can put a grill here in front of my fans and rad.
    here you'll see the SEXY Sniper M3 with the Intel 3770K in the stripped down case.
    I used my break to bend a bracket for my rad support. came out pretty good...
    Now time to lay out the wcing before the case goes for paint! :)
    Thank you FrozenQ for the FlexTank it fits perfect!
    Now time to sleeve some wires with MDPC sleeve.....
    Until next time.....
  3. Mizugetsu
    Mizugetsu What's a Dremel?
    12 Aug 2008
    Some interesting ideas i'm looking forward to seeing this to fruition
    Good luck and have fun
  4. AciD_RaiN
    AciD_RaiN What's a Dremel?
    29 Jul 2012
    Looking good mate... Love your work as always :D
  5. PcJunkie209
    3 Sep 2011
    Thanks. It's actually already done I'm just really behind on a lot of logs. :(
  6. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    Like the sleeving. Nice job drilling all those wholes, it looks original. I am also looking forward to seeing this one finished.
  7. PcJunkie209
    3 Sep 2011
  8. PcJunkie209
    3 Sep 2011
    Thanks. :)
  9. PcJunkie209
    3 Sep 2011
    Ok so I better get on with this log before it never gets done! :)
    Here is how it looks after some cool airbrush work from my friend Nano
    Ok so on with the build. Time for some hardware....
    As you can see its a very tight fit with the GTX680
    Here I added some Mayhem Aurora Exstinction Green liquid.
    Here you can see again how much measuring I had to do to make sure all would fit. I installed the top brace and fan cradle with not a cm to spare....
    Time to wire manage the PSU and install.
    Thats it for now. Still need to install SSD's.
  10. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Sugo case.. that takes me back...
    Nice mod man!
  11. PcJunkie209
    3 Sep 2011
    Thanks bro!
  12. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    epic paint job :thumb:
    Definitely grabbed my attention!
  13. PcJunkie209
    3 Sep 2011
    Thank you. It's the same pattern from retail box. :)
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Great military mod. ;)
  15. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Liking that well done, gotta love SFF machines with some big grunt :D
  16. PcJunkie209
    3 Sep 2011
    Thanks you!
    This is actually my first real SFF mod.:)
  17. PcJunkie209
    3 Sep 2011
    Ok so I'm gonna finish this finally...
    One thing I forgot to plan for was the two Pyro SSD's so this first pic was not gonna work... :)
    Here's installing windows
    This is better for the SSD's
    Front shot with glass installed again.
    Final pics...
    Thats it for now I'll post some pics from PAX Prime on display.
