Hardware SilverStone SX600-G 600W PSU Review
Discussion in 'Article Discussion' started by Combatus, 16 Jan 2015.
  1. Combatus
    16 Feb 2009
  2. Shirty
    18 Apr 1982
    It's a lovely unit, no doubt about it. But I worry that 600W is overkill for the types of systems that will necessitate a SFF PSU.
    I run an OC'd 3770K and 980 and I don't even get up to 350W when benching.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    A 295x2 might want to have a word with you. It's a big card, but still possible for an SFF build.
  4. Shirty
    18 Apr 1982
    There are potential scenarios where one might try to cram a dual GPU beast into a small space, but those have to be few and far between? As in, hundreds of times a year across the world. I'd be uncomfortable going as low as 600W with a 295x2!
    I suspect they are hoping that most people just think "more is better" when making PSU buying decisions, and that will shift enough units to have made the project worthwhile.
  5. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    that's a very fair point tbh. Our system went up to 665W with the 295X2 under load so I'm with you on not wanting to go as low as 600W there!
  6. Lankius Maximus
    Lankius Maximus Minimodder
    21 Aug 2009
    I'm using one in an Ncase build at the moment and it is good.
    I know there are some documented issues with fan noise and coil whine but for its size it is relatuvely quiet. I get a strange high pitched noise from the psu after about 15 mins/ Its similar to the noise you get from older cars when the fan belt is trying to gain traction and then a brief chirping noise as the fan speeds up otherwise I cant moan.
  7. Shirty
    18 Apr 1982
    In my mind's eye I can envisage a very small mATX case utilising this PSU, so you could enjoy some Maxwell SLI action but keep the external dimensions small. I'd buy that - just imagine the horsepower you could cram in using a pair of those dinky Asus 970s!
    *creams pants, twice*
  8. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I see this becoming the 'go to' SFF PSU even at £99ish as the next one down is the 450 which is only £12 less although the non-modular model is significantly cheaper at just under £60. (Prices compared are from Scan)
    I would like an article/review of the 450 non-modular model, not for a review of the PSU itself but as a modern guide of the issues that you might face using non-modular cables in newer Mini-ITX cases.
  9. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    For readability's sake, it might be a good idea to have graphs on the same page use the same scale. e.g. the efficient test page has some graphs using 0-90 as the scale, some using 0-100, and none using the same scaling facto.
  10. Dogbert666
    17 Jan 2010
    Hmm, that's to do with the back-end graph generator; it auto-scales based on the figures in the graph. I guess with only two figures per graph it's likely to change often. Tbh I just read the numbers and the rankings, it's very clear to me, but I work with it all the time so it's also probably to do with just being used to it!
  11. Aibohphobia
    Aibohphobia What's a Dremel?
    16 Jan 2015
    This may be relevant to your interests then: http://hardforum.com/showthread.php?t=1816110
    I went crazy though and I'm running a 5930K and SLI 980s off this PSU :D
  12. Cheapskate
    13 May 2007
    I got one of these. The only issue so far was it being boxed in a single layer of bubble wrap. What made it even more dicey was that I ordered it from Amazon, and they shipped it loose in a big box with TWO packing pillows.
  13. Arboreal
    21 Jan 2011
    Hi Aibo,
    didn't know you were a visitor to these parts :rock:. I'm not worthy...
    Been watching your Nova case concept developing over the last few months and am in awe of where you've got to.
    Looking forward to seeing how it all goess.
    For me ITX has to be in a properly small case (no Prodigy for me!) as you can get mATX in 17l ITX has to do better.
    It's great that Silverstone are pushing the limits on SFX PSU capacity without much compromise or downsides.
    All power to Kimera Industries I say!!
  14. Aibohphobia
    16 Jan 2015
    Thanks Arboreal,
    Though I'm amazed at all the talented modders here, I just pushed some pixels around a screen and let someone else do the dirty work of manufacturing :p
    I think a big problem with ITX cases is supporting ATX PSUs. A 160mm modular power supply is huge compared to the SX600-G and so it dictates the size of the case.
    Going for only SFX, or even the larger SFX-L, would cut the possible case size dramatically.
    PSA: If you're annoyed by the chatter of the stock fan on the SX600-G, do NOT try to swap it like has been done on the ST45SF-G.
    The SX600-G uses a 0-5V operating range for the fan.
  15. Shirty
    18 Apr 1982
    Now that is what I'm talking about :rock:
  16. Parge
    16 Jul 2010
    I hope they sell an absolute TRUCK TON of these and the market for SFX PSUs and cases goes as crazy as the ITX case and motherboard markets have over the last few years. Its about time we accepted a new standard. Thankfully we have forward thinkers like Parvum and Phanteks in the industry, and its not the impossible dream it once was.
  17. Nexxo
    23 Oct 2001
    I'm buying.
  18. Aibohphobia
    16 Jan 2015
    Phanteks is innovative but I'm not counting on them to push SFF cases down in size, their mATX Evolve is bigger than some ATX cases.
    I think SFX-L is where it's at. The 120mm fan should help address the noise concerns compared to standard SFX but it's still quite smaller than ATX.
Tags: Add Tags
