Hardware Water-cooling the AMD Radeon R9 290X
Discussion in 'Article Discussion' started by Meanmotion, 10 Dec 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Must admit I simply love Aquacomputer's blocks, if only they covered more of the PCB though. I've ended up not using this one for a 290 as there is a lot of PCB, which doesn't look so grand really.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    It covers the chip, the ram and both the VRM points, nothing else is needed, my EK blocks are much the same.
    Might be worth noting that r290 and r290x use the same die and board so equally this applies to them for those who might not know.
  4. Maki role
    9 Jan 2012
    Yeah my complaint isn't really about it being needed, just not looking as nice. EK sells blocks that cover a similar area, but they also sell ones that extend to cover almost all of the PCB itself, even if they offer no additional cooling (I opted for Titan XXL blocks for that reason in my rig). You can see what I mean here:
  5. Panos
    Panos Minimodder
    18 Oct 2006
    Guys, something is wrong with those benchmarks, and I would expected from bit-tech better job.
    On 1920x1200 with 8AA the stock GTX780 has 2372 and the 290X under air 2176.
    While few days back, at 2560x1600 with 0AA, the stock GTX780 had 2298 and the 290X under air 2157!
    Which means that the PNY XLR8 OC or ZOTAC AMP! GTX780s which are 10% faster than the stock 780, beat here a water cooled 290X @ 1155?
    (Before someone calls me a AMD fanboy, I have a PNY GTX780 XLR8 and i7 4820K, just stating the obvious)
  6. Combatus
    16 Feb 2009
    Hi Panos. I'm not entirely sure what you mean but you do know that if you run Unigene at different settings, you get different scores? So if you run it at 1,920 x 1,200 with 8x AA, you'll get a different score in the same card as if you tested at ,2560 x 1,600 with 0AA. This is why a few days back we got different results, and in addition, the water-cooled tests were re-done on an entirely different system.
    As such, you can't really compare like-for-like these tests in this article with all our other graphics benchmarks as it wasn't conducted in our usual graphics test system due to practical reasons. I hope this explains why the results are different!
  7. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    I think what he's saying is that on the same settings, he was expecting the watercooled 290X to beat the 780, where at present, it isn't?
  8. Combatus
    16 Feb 2009
    Ah right okay. Well it's a pretty close call - watercooling the card does add a lot of performance compared to both 100% and 40% fan speed settings especially. However, we're testing using entirely different hardware and settings to other graphics reviews but the point of the article, really, is just to highlight the impact watercooling has on the R9 290X - here we used the same card, the same settings and the same system so I can assure everyone that these results are not wrong ;)
  9. Panos
    Panos Minimodder
    18 Oct 2006
    That is great Combatus. Cheers.
  10. TheMadDutchDude
    23 Aug 2013
    I'm confused about the temperatures. How does the core get to 72c at various different settings, including slower fan speeds? There's absolutely no way a card will stay as cool at 40% as it does at 100% fan at the same clock speeds. I've heard a 290X and seen the temperature differences. Are you sure they're correct?
  11. law99
    law99 Custom User Title
    24 Sep 2009
    be nice to see more wc testing... but I appreciate it is a ball ache what with leak testing etc all adding to the time and potentially expensive if you can't get the items as press items - let alone what ever you think your time is worth.
  12. sandys
    sandys Multimodder
    26 Mar 2006
    The card throttles clocks etc to not exceed 95c max temperature any further, the graph is delta T to ambient so ambient is probably 23c
  13. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    I was getting confused there too, didn't notice the delta!
  14. Combatus
    16 Feb 2009
    Correct! :D
  15. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    I'm glad someone finally benchmarked these cards under water cooling. In a multi-GPU and/or CPU overclock setup, it seems like water cooling is a must have if you want a reliable and quiet system. I'm sure the water cooling companies are thrilled, since water cooling was almost deemed unnecessary for the last couple years, except in some cases.
    I also particularly like how water blocks slim down the entire GPU, allowing you easy access to more PCI-e slots. Unfortunately, some of those GPUs still use both slot compartments due to the DVI or DP ports, but, if you have any PCI-e based SSDs, RAID cards, or maybe a GPU for PhysX, you could still use those since you don't need to reach the outside with them.
  16. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Damn I wish I knew how to water-cool as I'm too kak scared. Corsair H100i very easy but this and yet so damn tempting
  17. schmidtbag
    30 Jul 2010
    I've never done liquid cooling myself but as far as I'm aware, there are fluids you can use that aren't conductive. Personally, I've considered doing a computer completely submerged in mineral oil (in a fish tank), but I'm not sure if you can use mineral oil in conventional water cooling systems. I'm guessing the viscosity might be a problem.
    From what I've heard, the best way to do a water cooled system is to only power on the cooling system but disconnect everything else. Keep an eye open for leaks and if it happens to spray everywhere, you'll be fine. Contrary to what many people believe, water doesn't hurt electronics as long as they're uncharged. Every time I make an upgrade to my (desktop) computers, I take out most of the parts and clean them under a faucet and just wait a day or 2 for them to dry off. Its cheaper and sometimes more effective than air cleaners, and makes the stuff look like new when you're done.
  18. somidiot
    somidiot Minimodder
    18 Aug 2009
    I'd be curious to see the GTX 780 or 780 Ti water cooled vs this same setup across the regular benchmark suite, see how far each card can be pushed on water vs. air.
  19. law99
    24 Sep 2009
    I've had the equivalent of a whole mother ****ing bunch of water all over my **** and all I did was dry it out. Leak test the bits separately outside the case, then move inside and leak test for a solid 12 to 24 hours powering only the pump using the paperclip method on a psu not connected to your PC... then after the green light, you can go right ahead and turn it on.
    It is really simple, really, as long as you are methodical in testing and don't get carried away(add an extra trite really? Nah... ;) ).
    Only downside is it is more effort to chop and change components that are in the loop. The temp difference is a god send though. Love not worrying about overclocking... really is night and day. Can't go back. Only those all in ones could tempt me, but I'm more worried about one of those exploding than stuff I tightened up and tested myself.
    I was quite lucky adopting it at such a late point in my life also as it's all been figured out by other people by now. All the fittings, hose, pumps, rads etc.... simples.
  20. Panos
    Panos Minimodder
    18 Oct 2006
    With that need to put a modified BIOS also that unlocks the maximum voltage, that is hard set to 1.2v to all. (but EVGA Classified)
Tags: Add Tags
