On our desk this week - 8
Discussion in 'Article Discussion' started by Tim S, 27 Jun 2006.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    hmmm the can cooler is tempting......
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    That Microsoft keyboard is very good value for what it is. Their hardware is always quality - definitely worth buying.
  4. logan
    logan flashback!
    17 Aug 2002
  5. DougEdey
    5 Jul 2005
    Only £4 more then my standard one. Couldn't believe the build quality on this KB.
    Will have to get it when I get my job started!
  6. quack
    quack Minimodder
    6 Mar 2002
    Very tempted by the MS keyboard for work. :)
  7. Guest-16
    Guest-16 Guest
  8. excession
    excession What's a Dremel?
    8 Aug 2005
    What's the button on the top right of the MS keyboard? Just above the number pad? :eek:
  9. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    That Microsoft keyboard is a nice looking, ergonomic keyboard, does it come in a wireless option? Though even if it only comes in a wired config, it still is a nice looking and styled keyboard.
    Also, that media man external HHD enclosure/ encoder looks quite nice, but the price neends to drop like a lead balloon. The design is a biut hit and miss but the remote is a nice looker and looks like it will fit in a hand quite snuggly.
    But the best item on the desk this week, has to be the Coolit beverage chiller, fts nicely on desk and beats a minifridge for price and size, every time....
  10. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    <- still uses a ball mouse
  11. Veles
    Veles DUR HUR
    18 Nov 2005
    THat drinks cooler sounds pretty cool, tempted to try and find one of those.
  12. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    A quicklaunch key for the calculator. ;)
    I have a Comfort Curve and its pretty darned nice, I think I bought it a fair few months back from amazon for about a tenner (its gone up on there now, doh) though I find the proper split ones more ergonomic and didnt like the laptop keys much (at first) having now used it for about 4 months I can say its pretty nice to use.
    If you get one beware: It gets bloody dirty bloody quickly. unless you clean your keyboard regularly after about 3-4 days of exposure it will naturally get pretty dusty and the keys show all sorts of dirt and body oils and looks grim.
    Also another worthy note, it doesn't rise much from the desk which is a slight niggle. I would rather it have a bit more or an angle to it.
    If you can tolerate it, buy a "proper" MS natural one, but if you want a keyboard that will work well, has a very nice key press and genrally helps your wrists a bit get the MS Comfort Curve.
    Oh yeah. and I found it to be narrower than pretty much every keyboard I put it against.
  13. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    how does the cooler work internaly?
  14. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    The keys that are enlarged on the keyboard aren't enlarged because they're the most common keys used. They're enlarged because if they were normal sized then they would be awkward to hit while typing properly.
  15. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    The microsoft keyboard and cooler look really good! I need a new kb cos this one sucks and a drinks cooler is a must. How many times have you been sitting in your room with a can of beer or whatever and it gets warm while your playing games. Think i'll treat myself tomorrow!
  16. EK-MDi
    EK-MDi What's a Dremel?
    12 Mar 2006
    It is good yes, but not perfect. As in, it's not wireless :(. So close to being my next purchase:(.
  17. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    @ChromeX: I reccomend the MS Wireless Natural MultiMedia Keyboard (and the intellimouse explorer 2 while I'm at it). I've had it for about six months and I absolutely love it. Having never used a natural keyboard I found it a bit odd at first, but after about an hour I was converted. It has proper keys (i.e not laptop :p) and it feels very "natural". It gets five stars from me.
    -ed out
  18. lepre
    lepre Minimodder
    28 Aug 2003
    i had the MS keyboard curve 2000 black for a while now and i'm very proud of it. with only 15euros it's nice and not too big and it helps you to write "more correctly".
    i remembered about the enlarged keys only when i read it here...i totally forgot it :)
    and the calculator button works in linux too!!
    the only problem is that it doesn't work with a ps2/usb adapter so with old motherboard it's a bit tricky during boot (i have a ps/2 keyboard connected too under the desk)
  19. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    It's a pity the bottom of cans aren't flat. I'd suspect that when it comes to surface area, the amount of can exposed to air trying to warm your drink versus the tiny amount of surface area actually touching the cooling plate will mean that your coke is still going to end up at room temperature if you don't drink it quickly enough.
    A mini champagne bucket design would be a much more efficient way of cooling your cans. Or simply get one of those mini fridges.
  20. blaffer4x4
    blaffer4x4 What's a Dremel?
    13 Oct 2004
    ralph.pickering,
    now go, go and mod! :dremel:
Tags: Add Tags
