Modding Case Fan mod
Discussion in 'Modding' started by Simon bridgeford, 23 May 2010.
  1. Simon bridgeford
    Simon bridgeford i'm a pc
    25 Sep 2009
    this is my first mod, i thought i would start off small!
    mvagusta likes this.
  2. Arj12
    Arj12 What's a Dremel?
    6 May 2010
    I would love to have this right now! It is absolutely BAKING here and some air movement would be very welcomed!
  3. badman_mo007
    badman_mo007 What's a Dremel?
    6 May 2010
    LOL how much air do those fans pump?
    dont set them on max or your eyes will dry out and get shrivelled haha :D
  4. Simon bridgeford
    25 Sep 2009
    they pump out enough air but not enough to dry my eyes!
  5. Chaos_Engine
    Chaos_Engine What's a Dremel?
    16 May 2010
    genius, struggling in this heat how about 3 X 120mm! peel your eyelids back !
  6. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Line Vantec Tornados across the top of the monitor....
    :thumb:
  7. bulldogjeff
    2 Mar 2010
    I can see this style being the next big thing:D
  8. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    I guess the temperature is really hot outside. More FANS ! MORE FREAKIN MOD ! MORE CFMMM I want to be Frozen
  9. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Does it float?
  10. Simon bridgeford
    25 Sep 2009
    no, it is attached to the screen using blu tack:rock:.
  11. Krog_Mod
    Krog_Mod Minimodder
    23 Sep 2003
    You should make a case for them that matches your speakers. Make it look like a center speaker and you'll have a nice breeze without anyone knowing where it's really coming from (unless they're loud fans).
    How are you powering those btw?
    Edit: Never mind, I just saw the PSU beside your monitor.
  12. Simon bridgeford
    25 Sep 2009
    i think if i put silver mesh over the fans they would become useless.
    i am using a power supply with the green cable earthed so the psu turns on, and then i have just connected the fans as you normally would.
