So Slow...
Discussion in 'bit-tech Folding Team' started by Votick, 29 May 2009.
  1. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Why is my folding so slow?
    Most my PPD is from a PS3 which seems to be doing more than this lot:
    http://votick.is-a-geek.org/
    How can i speed them up?
    Thanks
  2. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Initial question - what is your hardware and OS?
    Second question - what projects are you running (you had no choice, but the PPD can vary a lot between projects)?
    The PS3 should be getting about 900PPD.
    The Athlon 3500 figure may be OK - depends on project
    The GPUs can probably be improved
  3. Votick
    21 May 2009
    Ok well hardware and OS:
    8500GT - Windows Vista Home Premium
    Server - 8600GT - Windows Home Server
    AMD Athlon 3500+ - Windows Home Server
    Sam-PC - 8600GT - Windows XP SP3 (This one is sometimes on when not gaming)
    Just adding a AMD 4800+ which is running on Windows Vista Ultimate.
    And for prodjects I ealy do have no idear.
    The 3500+ is the slowest out of the lot :(
    Takes days to fold for crappy points :( But its for a good cause :)
  4. Unicorn
    25 Jul 2006
    Just a quick question - Which guide, if any, did you use to create your fahmon web template? I'd like to put a link to one for my folding in my farm thread :)
  5. Votick
    21 May 2009
    I did use a guid :) sorta looked around in prefrences and notice the export web application.
    I just set it to save it in a webfolder on my server and made it public via a url. Keeps its self updated :) Pretty good so far.
    I can try get some screenshots for you if you want :)
  6. Votick
    21 May 2009
  7. Unicorn
    25 Jul 2006
    I'm in the middle of doing it myself using that guide, googled for it and came across that one, cheers! :thumb:
  8. Votick
    21 May 2009
    if the guid dosn't work then I would suggest running WAMP.
    Which runs a webserver on your computer. (Windows Apache, MySql, Php - i think lol)
    The setting fahmon to export the template into the www folder of WAMP in C:/wamp.
    The portforwarding the corrent ports for html. 80 is the main one i think.
    Then get a url to point at your ip, or get a dyndns url form a website and pont your url to that if you have a non-static ip.
    ethier way im sure you will figure it out :) nice farm by the way :)
  9. Unicorn
    25 Jul 2006
    Thanks, I'll give it a go and see what happens ;) Don't worry too much about low PPD today btw, mine is desperately low on all hardware today as well. Tough WU's and projects are to blame.
  10. Christopher N. Lew
    23 Apr 2009
    Go to FahMon, View, Show/hide WU Info panel. Highlight client of interest.
    It doesn't surprise me that the Athlon 3500 is the slowest, and takes days; so do mine.
  11. Votick
    21 May 2009
    Dose the webtemplate i linked show the projects?
    e.g. Project: 5749 (R3, C229, G182) ?
  12. Christopher N. Lew
    23 Apr 2009
    Not when I click on the link in your sig
  13. Votick
    21 May 2009
    hmm seems to work for me.
  14. Unicorn
    25 Jul 2006
    +1
    CNL - The different clients in the webtemplate are clickable ;)
  15. Votick
    21 May 2009
    How is yours going by the way, Any luck?
  16. Unicorn
    25 Jul 2006
    Havent tried it just yet, was about to start ;)
  17. Votick
    21 May 2009
    Ok if you get stuck feel free to ask :)
  18. Unicorn
    25 Jul 2006
    I am stuck but I doubt that you will be able to help :grr: I can't login to the Genuine Gaming webserver ftp.
  19. Votick
    21 May 2009
    ohh yeah I cant help there im afraid.
    hehe passwords, infomation and bits.
    :nono::nono::nono:
  20. Unicorn
    25 Jul 2006
    It's not the password or login name, I can access those through my control panel. It's the actual FTP url - My host has disabled FTP acces to the server. Needless to say i am about to call them and give out yards. :grr: :nono:
