News GPUBoss.com launches as a companion to CPUBoss.com
Discussion in 'Article Discussion' started by Gareth Halfacree, 29 Mar 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. toolio20
    toolio20 What's a Dremel?
    29 Jan 2011
    Terrible site, definitely aimed at keeping the uninformed layman uninformed...NOT a site for enthusiasts, and NOT one that should be plugged on a site for enthusiasts.
  3. Gareth Halfacree
    4 Dec 2007
    Really? Care to elucidate? I rather like it.
  4. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    need something like this for when you're trying to compare laptops
  5. pantalaimon
    pantalaimon What's a Dremel?
    23 Mar 2011
    Really cheesy site. Don't like it at all.
  6. thom804
    thom804 Minimodder
    22 Oct 2009
    Hmm, yes please elaborate.
    For exact comparisons it's not anandtech, but for a quick glance at how your current gpu stacks up to competition and if you need that upgrade, it's really user friendly.
  7. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    I find this actually great for a quick compare between especially the K and non K versions of Ivy bridge for someone with no need for overclocking some systems. Its brilliant. Its easy, it gives a quick break down with no hassle and exactly what the main pros and cons are for the average user and what the difference will be at a glance. Brilliant idea to do a gpuboss, harder to make the comparisons but something for EVERY group of people whether expert or amaetuer.
  8. LightningPete
    2 Jul 2009
    Infact along with CustomPC/Bit tech this is one of the deciding factors between nvidia and amd cards or amd and intel cpu based systems. Im intel and nvidia fanboy i must admit but if the specs are the same and the former or the latter is cheaper im obviously choosing the economical choice :)
  9. thom804
    thom804 Minimodder
    22 Oct 2009
    I wish i'd seen your personal website sooner Gareth. i would've snapped up that C64 in a second!
  10. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Actually more useful than CPU comparisons. CPUs are fewer in number and easier to compare.
  11. David
    7 Apr 2009
    I'm struggling to work out who it is aimed at. The discerning PC geek will already have an appreciation of comparable performance from reading reviews and lab tests, and isn't usually looking for the simplistic "Better than, yes/no"advice the site offers.
    Pretty much everyone else, won't have a clue what a CPU/GPU is and will go to the IT Geek in their circle of friends, or PC World (shudders).
  12. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    But do you want to spend hours reading reviews and lab tests, or get a quick idea of performance and then read more about the specific details after you have a rough idea of whats what.
    I think if you used it as your only comparison it could be foolish, but used as a quick comparison i think it has its uses.
  13. David
    7 Apr 2009
    I enjoy reading reviews and lab tests, as do many enthusiasts. That was my point.
  14. Harlequin
    Harlequin Modder
    4 Jun 2004
    found a funny one - it reckons a 6870 is better than a 5870 oO
  15. Corky42
    30 Oct 2012
    But not everyone has the time, that was my point :p
