Scratch Build – In Progress -----'PARVUM SENESCENTIS'-----
Discussion in 'Project Logs' started by imersa, 1 Oct 2014.
What Colour Acrylic Accents?
  1. Light Silver
    2 vote(s)
    6.7%
  2. Silver
    1 vote(s)
    3.3%
  3. Slate Grey
    18 vote(s)
    60.0%
  4. White
    2 vote(s)
    6.7%
  5. Clear
    7 vote(s)
    23.3%
  1. imersa
    imersa Parvum Princess
    9 Apr 2009
    Hi everyone. Time for a little project. This is actually a 'filler' project log. Just something a little different for me and to work on something until the next big project. When I say different we have and plan to explore many new techniques and materials in this build.
    There shall not be any watercooling here either which actually will be a big first for me. Something I'm actually looking forward to.
    Due to the nature of how busy we are with Parvum this will be kept a somewhat photo based project log. I'll be more than happy to answer all questions as we go but the text will be kept to a minimum in the project.
    This build is possible with the support of Intel, Hyper X, Nvidia and Republic Of Gamers.
    I tend to gather a series of images and physical items as project inspiration before I start anything. I thought I would share them:
    Main Components:
    Case - Custom Steel Parvum X1.0
    CPU - Intel i5 4670k
    Motherboard - Asus Maximus VII Impact
    Memory - Hyper X Unknown
    GPU - Asus GTX 750Ti
    SSD - Hyper X Unknown
    PSU - Silverstone Strider SFX 600
    Miscellaneous:
    MDPC-X Sleeving
    Large Coolers - Prolimatech Genesis CPU Cooler & Alpenfoehn Peter 2
  2. imersa
    9 Apr 2009
    Steel case panels & ageing the metal coolers
    We start with the stock coolers for the project. It's going to be EXTREMELY tight to fit the CPU cooler but we will make it work. In their retail form.
    I wanted to keep away from the very bright chrome so we had to step into some unfamiliar territory here. I'm usually not a fan of making things look aged or old but really wanted a rough and organic feel here. I suppose with an architectural background; the desire to mix rustic and aged with clean and sophisticated was always to our taste.
    We first sanded the nickle plating with a fine grit and dunked into a a bronzing solution to eat away at the coolers. We wanted to add hints of colour so we chose to flame heat the steel finishing plates for the CPU cooler.
    Next up some of the base panels for the case. Laser cut entirely from 5mm thick mild steel. We then left the panels to weather a little. The rebated holes and chamfered edge have been done by hand. We then sanded down some parts of the panel and left the raw look here. We sealed the panels with a lacquer to prevent further weathering and darken down the over all look.
  3. Arboreal
    21 Jan 2011
    Holy Z! a steel Parvum... :jawdrop:
    Looking forward to seeing how this goes, a diversification into heavy metal.
    Can you do aluminium too????
    Suuuuuuuubbed
  4. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Hurhurhur.........
    Someone was listening......
  5. imersa
    9 Apr 2009
    We have just started to cut metals with laser yeah. That said its not on site, we are still focusing full efforts in acrylic. Metal is a weekend job :D
  6. Arboreal
    21 Jan 2011
    Great stuff Justin, pleased to hear you're busy, metal at the weekend sounds a bit of a Busman's Holiday - ohhh the dedication.
    No w/c this time, bit of a shocker for you...the horrors of air cooling.
    I do like the aged look, entropy Cheesecake! It's going to be a HEAVY rig in 5mm steel, I shan't be lugging one to the weekly LAN.
    One question [I know you're busy] could the ITX case design be extended vertically to take a mATX board with the other 2 dimensions remaining the same???
    My ITX is 1/2 assembled, and now I have the right board [Max VI Impact] I can get building when the CPU comes and I have chosen a cooler...
    Keep up the good work :dremel:
  7. bulldogjeff
    2 Mar 2010
    Ok I'm interested.. this should be interesting..
    Aluminium, hmmmmm
    How about something similar to the case labs M8 but bigger in aluminium of course.. Big enough for me to get at least 4 triple rads in. I could have hours of fun with something like that.
    Just an idea ...lol:D
  8. The_Crapman
    5 Dec 2011
  9. imersa
    9 Apr 2009
    erm it MAY be possible. I'll have a play around and post a few little sketches in the thread next week :)
  10. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    J, awesome stuff but one Q, when will we be able to get big cases? When, where (well, we know that :hehe:)?
    Magnus, X1.0 (BTW, using that numbering, you saying something about this case being available).....I could give them a home.....:D
  11. Arboreal
    21 Jan 2011
    No panic, more an academic question for the moment.
    Don't want to distract you from the day job or the new ironclad construction :D
    I need to get myself into gear and get the custom Parvum ITX put together and on BT
  12. imersa
    9 Apr 2009
    Small update. More than anything we need to choose the acrylic colour for the accents and mid wall. I have taken a number of photos of the choices we like and have considered for the project. If I'm honest we do want to use acrylic here.. because we love acrylic!
    I have posted a poll for you to choose your favorite. The numbers are labeled here:
    Full information on choices:
    1. Colour - Light Silver / Finish - Gloss Metallic / Light transmittance - NO
    2. Colour - Silver / Finish - Gloss Metallic / Light transmittance - NO
    3. Colour - Slate Grey / Finish - Frost Matte / Light transmittance - YES
    4. Colour - White / Finish - Frost Matte / Light transmittance - NO
    5. Colour - Clear / Finish - Frost Matte / Light transmittance - YES
    More photos of the samples with one of the panels as a reference:
    Hopefully with the above photos this will give you all enough to make an informed vote. I know what I would chose but I must say I was pulled towards a couple.
    I will be going ahead with the winning vote Monday/Tuesday of next week so we can get these parts cut and the thing together.
    In other news; Asus ROG have sent the board. Thanks guys. A shot of the thing (You've all seen the Impact by now) and a photo with bits removed:
    Now to think about what we can do with these easy to remove bits :D
  13. Arboreal
    21 Jan 2011
    ^^ This - voted for it too :D
  14. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Yeah of the selection, I think I like slate grey the most. Although saying that, silver is pretty good IMO, just a tad light though. Something like a cross between the silver and slate would be awesome, but failing that, yup slate.
  15. Parge
    16 Jul 2010
    OMGeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
    I love love love apocalypse industrial projects. Cannot wait to see how this turns out!
  16. imersa
    9 Apr 2009
    Thanks for all the voting thus far everyone. I will compile results from all 3 forums and let you know the answers. I will also post the most interesting reasons behind the winning votes.
    Oddly black slate is the clear winner so far here but frosted clear going high at another forum.
  17. Maki role
    9 Jan 2012
    Black slate it is then! As you know, we clearly have the best taste...
    (sorry OCN, tis true)
  18. imersa
    9 Apr 2009
    Results:
    1. Light Silver - 6
    2. Silver - 2
    3. Slate Grey - 21
    4. White - 6
    5. Clear - 23
    So with that I will cut and try to post photos of the case built with the frosted clear tomorrow. If for whatever reason we at Parvum and you guys think it doesn't look great we will cut the Slate Grey and compare. It makes sense because votes our quiet close.
  19. B NEGATIVE
    8 Aug 2011
    White.
    You will get great contrast between the degraded and rusty Iron to the pristine pure white....
    Or Magenta,if you can get it.
  20. imersa
    9 Apr 2009
    So you show up when I post the results and decision? Lolol
