Other Origin - why you anger me?
Discussion in 'Software' started by AlienwareAndy, 16 Jun 2013.
  1. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    OK so I have an issue with Origin that is really pissing me off..
    Steam ? now that I love. Basically if I have to reinstall Windows (which I do a lot given I'm a hobbyist reviewer/tinkerer) all I need to do is download the Steam installer, point it to my Steam DIR and bingo bongo ! all of my lovely games are immediately detected and ready for me to play (well, after any initial DX bits).
    Origin? why are you such a hateful bile spilling pile of cack?
    I download the Origin installer, point it to my Origin install folder.. None of my games are detected, leaving me to download 40gbs of them to get them back in there. It's OK with Crysis 3, NFS : The Run and BFBC2 as I have the media, but BF3 came by ways of a code that I got free with a GPU.
    So does any one know a way to get it to see the data, rather than forcing me to download it all again? or, should I just buy the media?
    This is the biggest reason why I haven't removed my optical drive (well, that and the fact that games are much cheaper on Amazon as hard copies which is kinda stupid).
    I'm really getting to the point where I'm just going to remove Origin and hack all of my games with no dvd or whatever just so I don't have to keep continually downloading them :(
  2. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    There's a backup/restore guide on the Origin forums, not sure if it's any use though or if you have the files in the format that is described below.
    mikeyandrewb and boiled_elephant like this.
  3. AlienwareAndy
    7 Dec 2009
    Hmm. I have several drives in my PC so I'll try that.
    Thanks !
  4. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Repped for useful informations, I think I'll be writing this down somewhere.
  5. AlienwareAndy
    7 Dec 2009
    No folder called Disk1. Bummer.
  6. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    There's another guide here.
    Basically start the download so it creates the folder structure then copy your stuff in and restart Origin.
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    I've re-done my origin folder several times , like CrazyJoe suggested.
    install origin, start download, close origin, copy in your back-up game folders, restart origin .. and away you go.
  8. AlienwareAndy
    7 Dec 2009
    Yeah that sounds like a winner :D
    Cheers !
  9. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    weird I just installed origin and cope the entire Origingames files into the origingames folder. then either reload my games or reboot my PC works ever time for me. (yeah even for BF3 but I do sort out my divers correctly and windows update) Win7 is a B@&$! if you do not install SP1 correctly and .net origin uses .net so this is a requirement. (most ppl forget that)
    sometimes is says downloading the first time but you can see by the speed and i got a 100mb Internet connection that its actually verifying the data and not downloading.
  10. spolsh
    spolsh Multimodder
    4 Feb 2012
    You know, I don't remember if I even tried such a simple fix when I've done it MSHunter, I may have justa assumed it'd have been made tricky that I automatically googled for a solution - Think I may have assumed it would have been awkward, as it's EA.
  11. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    yeah had to do this recently when I got win8, mad the classic mistake of trying upgrade option instead of fresh install, naturally nothing worked well, at least new AAA games. did the win8 complete reset and installed the win8 GPU drivers now everything except RA2 works 100%
  12. boiled_elephant
    14 Jul 2004
    Hey, speaking of which, I tried to reinstall BF:BC2 on Steam just now on my fresh installation of Windows. It said my product key had already been used (well, duh - I used it on my last installation!)
    I googled it and apparently, when reinstalling, your only option is to contact Origin tech support directly and get them to unlock your key.
    So, not even like GTA4's horrible DRM that forced you to download a utility and generate unlock codes - this one actually won't give you back your game until you call tech support. No, really.
    I tried to log in to my Origin account along the way (thinking I might have more options from in there) and got this:
    I then tried to get onto tech support and was presented with this:
    This is simply retarded. I have no other word for it.
  13. ferret141
    ferret141 Minimodder
    18 Oct 2010
    I can see this method messing up
    This is the method I would use and have successfully for about 15 Win7 re-installs.
    The only extra thing I do is rather than close Origin I pause the download first. Then close. Copy stuff over. Open. Re-initiate download. Then it verifies game data integrity so it knows what to download. Finds everything up to par. Job done.
    Why are you installing SP1 separately and not using an MSDN slipstream?
    Weren't you able to use the same folder copy method for BC2?
  14. boiled_elephant
    14 Jul 2004
    I'm installing via Steam. I used the folder copy method (always do when reinstalling Steam) but I guess it's seen too many different CPUs now, or something. So I'm stuffed; I can't get my BFBC2 back, other than by waiting half an hour in a queue and then pleading with an EA employee to relinquish it to me.
    **** EA. Just **** 'em. At least when Steam have invasive, rights-curbing DRM, it works.
  15. ferret141
    18 Oct 2010
    Seems like you've activated on too many installations without de-activating it before. You get something like 10 activations.
  16. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    Just login to your EA account when you open BC2 and it works, did for me anyway on multiple systems. You don't need to enter your cd key at any point, like you say, it won't work since it's been used.
    That's how it works for me anyway...
  17. boiled_elephant
    14 Jul 2004
    When I log in, it asks me for mine, and then says it's already been used. It's been on about 4 different installations of Windows, that I can recall.
  18. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    Have you tied your key to the Origin client? Maybe it checks if the game is registered to your account when you login.
  19. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    this means you regged the game under a different email. try all your old email addresses. Really try them all especially the ones that you nolonger use. either that or you misspelled you Email when regging the game. then you need to contact support of course.
  20. boiled_elephant
    14 Jul 2004
    Today I just tried the same one in-game as before and it worked :confused:
    Swear to christ, I did everything exactly the same. Origin profile page is now working too, but doesn't give you any info about games tied to the account.
    Anyway, BFBC2 doesn't show up in my Origin client. I guess you can only have the game tied to one platform?
