Watercooling Haf X Watercooling
Discussion in 'Hardware' started by TheHound, 21 Apr 2012.
  1. TheHound
    TheHound What's a Dremel?
    21 Jul 2011
    I just received a rather marvellous present from the tax man totally £1600 and have decided to blow the whole lot :rock:
    I'll be getting a GTX680 soon and want to watercool that along with my CPU.
    My question is, with a 360rad, are the 2 200mm fans at the top of my haf x enough to cool the rad or will I need to add some to the under side of the rad?
    As in have 3 120mm fans under it with the 200mm fans on top.
    My Specs
    i7 2600k
    gtx580 (soon to be 680)
    8gb Kingston 1600mhz RAM
    Asus p8p67 deluxe
  2. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    I would remove the 200mm fans completely, as they will most likely have a negative effect on airflow through the rad. It is also somewhat pointless to watercool the 680. You might be better of spending the money elsewhere.
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    If you want to watercool it look at my thread (link in sig) as the first part was when I watercooled my HAF 932 which is basically the same as the HAF X.
