Case Mod - Complete ⭐ MODZERO JUICE - NFC SYSTEMS S4 MINI #80 (FINISHED 13.12.17)
Discussion in 'Project Logs' started by MODZERO, 15 Dec 2016.
  1. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    UPDATE 0
    I've been looking forward to this one for a while now. Unlike some of my previous builds this one should be pretty much stress free (fingers crossed). It's not a competition entry with a deadline, it's not a buddy build, nor a personal rig upgrade leaving me living off a test bench until complete. This one is a goody, a new LAN rig, in a chassis I'm super excited to build in. With no end date *cough* i60 LAN in April *cough*, so come along and enjoy the journey.
    This is a sponsored project, for which I'm hugely grateful! Massive thanks go out to NFC Systems for their support, E22 for once again showing their faith in my work and indeed Gigabyte for taking the risk and hooking me up. :thumb:
    SPECS:
    • INTEL CORE i5 - 6600K CPU
    • HYPERX FURY DDR4 2400MHZ 16GB (2X8GB) RAM
    • GIGABYTE GA-Z170N GAMING 5 MOBO
    • GIGABYTE GTX 1060 ITX OC 6G GPU
    • SAMSUNG 960 EVO M.2-2280 250GB NVMe SSD
    • HDPLEX Hi-Fi 250W DC-ATX PSU
    • NOCTUA NH-L9i COOLER
    • 2X SCYTHE KAZE JYUNI SLIM 2000RPM
    • NFC SYSTEMS S4 MINI CUSTOM CHASSIS
    After my beloved Parvum Veer (MODZERO FOUR) took a savage thieving (of it's mod cubes) in order to complete my Thermaltake UK modders trophy 2016 entry I was left without my LAN buddy. That was back in late April. I'm pretty sure I'd seen the NFC PURIEL build someplace and went in search of more information. That took me to YouTube and there I met the S4 Mini.
    Once MODZERO OCTO was finished I kept coming back to that S4 Mini I'd seen. At that time the GTX970 was about as powerful a GPU you could fit in the little monster (although couple folks over on the SFF forums had got the AMD Fury Nano running pretty stable too..) but the 10 series was coming soon and with it I was sure one of the board partners would put out a great ITX card.
    I'd contacted Josh at NFC about sending me the S4 Mini with the panels bare. At the time, very day I was driving past a BMW garage and had found a liking for some of their blues. A M4 in ESTORIL BLUE to be exact. The more I saw of it the more I liked it. From the chromed trim accents to the deep red of the rear light housing, I liked how the black of the grill contrasts against the blue metallic paint work. The actual paint work was done by B-Negative and he nailed it! Thanks buddy!I left the panels to truly harden then went about giving it a cut and polish. I had the color I wanted, so that was it, I'd base my S4 Mini around the aspects of the BMW M4 I liked.
    THE NFC SYSTEMS S4 MINI
    Many may already be aware of this chassis or at least Josh and his years of great work in the modding community, for those that aren't, this is the NFC S4 Mini. A 4.3l air cooled ITX chassis designed by Josh, manufactured in small batches and sold direct from his NFC SYSTEMS website. You can find out a lot more about it over on his page but for now I'll just show a couple shots of mine.
    This way up?
    Or this way?
    I think I'm leaning toward the second, there are vents under the Alu wrap-around and as we know, heat rises. With the GPU being that end of the case, I think I may see some performance gains in this rotation.
    You can just about make out the vents under the Alu panel.
    As the build progresses I'll drive inside the chassis and show some of that, I may take a second pass at the cut and polish I think there are areas for improvement.
    Outside of the custom paint work and sleeved cables I plan to make some modifications to how both the CPU & GPU are cooled and try my hand with some other materials to help make some of the internals really pop.
    Thanks for check it out, hope you stick around and enjoy the log.
    J.
  2. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Glad you like the paint buddy,always a pleasure for you.
  3. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Thanks again sweet cheeks! :p
    J.
  4. Cheapskate
    13 May 2007
    Follow link..."sold out."
    Well, that saved me from an impulse buy of something I didn't need. :lol:
  5. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Hahaha, NFC have a new batch of chassis on route, should be available early next year.
    J.
  6. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    UPDATE 1.0
    Well, now Christmas and New Years is out the way things are coming together nicely. Pre-Christmas I was still two key components shy of a POST. The M2 drive and a power adapter. I'll share my tale of the 960 EVO another time, as for the power brick, well that made for quite the odd Christmas morning gift unwrap. Turned out, my other half had being sending cheeky emails to KustomPCs. Knowing what I needed, they sent the power adapter inside a Corsair VS450 box. She then wraps the VS PSU box and come Christmas morning I fain adulation as she watches me remove the wrapping paper with an expression of 'erm...this isn't right', just as I then get over excited at the sight of the Dell ADP-330AB B Power Adapter inside.. She* is a keeper. :blush: I'd no idea she'd hooked that up, much impressed.
    *the power adapter
    I've had the Gigabyte goodies out ready for a box bench test. The plan being, I'll test all hardware stock (as we all do... :eyebrow:) outside the chassis first. Then run some stress benches with all the hardware test fitted in the S4 Mini before I start working on the cables. I'm running a 95W CPU and a GTX1060 + M2 SSD off a 250W PSU, I wanna be certain I'm not pushing my luck.
    It's a cracking little board, logical placement for SATA (yeah Impact... whats that all about!) and the 8PIN/24PIN are both where they should be.. surprising how many ITX boards are still getting this wrong.
    GIGABYTE GEFORCE GTX1060 ITX OC 6G - When they teased this and it's big brother the 1070 ITX OC a few months back I got really excited. I'd already been eyeing up the S4 Mini but none of the GPU offering at the time (under 8") were doing it for me.. back then it was a toss up between the Asus GTX970 ITX or AMD FURY NANO. Having just moved from the 980 to the 1070, the thought of buying a 970 gave me no pleasure. I'd have loved a FURY NANO but that 175 TDP wouldn't have left me much headroom.
    It's a chunky little monster with a beefy heatsink. It absolutely fills the S4 mini GPU space but seeing as the 1060 PCB is a little less tall then the its big 1070 brother I'm hoping I'll be able to mount the power socket without any further mods.
    I'm using the Noctua NH-L9i, I may or may not swap out the fan.. with such a small chassis, cooling is key. But I'm a sucker for aesthetics. Don't get me wrong, I like the signature Noctua fan color, however I prefer the nickel heatsink under it. Same with the GPU, so I'll at least try swapping out both 92mm fans for these Sythe 12mm 2000RPM 120mm beauts.
    The S4 Mini has those two 120mm mounting points, one over the CPU, with the other above the GPU. I'll run a suite of benches with the stock cooling options then repeat with the slims. See how we get on.
    I'm working on a custom backplate for the 1060 with a matching plate for the chipset. Exploring a few different approaches with that. Once I have the designs I'll see what you guys think.
    J.​
  7. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    UPDATE 2.0
    Over the last few days things have moved along nicely. These are simple phone shots and for some silly reason when resizing (I thought they looked cool at the time), I made them B&W. Won't be going that again..
    I'm really enjoying the S4 Mini chassis, it's the first independently produced small production run case I've bought. Josh over at NFC, clearly loves what he's doing. His enthusiasm comes through in everything. Already a world class modder and scratch builder (just check these out) he's also producing great content for his YouTube channel with the S4 Mini chassis clearly being a passion project for him. This is how the chassis looked when It turned up at my door. Before I sen it south to the mighty B NEG and his spray-gun of justice... :rock: (Not that you can really tell.. cos I made the bloody images B&W!! haha).
    I loaded up all the hardware and got windows installed onto the M2 drive.. I was expecting that to be a headache but everything worked as it should, happy days! (first time using M2) As I'm replacing all the cables for the HDPLEX with custom made 18AWG wire based replacements I didn't bother installing the PSU and ran it as seen above.
    The HDPLEX really is a great bit of kit! years of using overly power equipped PSUs left me worried a 250W DC-ATX PSU wouldn't get the job done. On a side note they've just replaced this a 300W model (yeah... :wallbash:) with a different layout for the connections ( better suited for the S4 Mini). However this one is going a great job, If I were to swap out the 1060 for say the 1070 then maybe I'll look at buying the 300W.
    My original intention had been to sleeve all the cables, but after I'd test fit the PSU.. and it left me with this...
    I quickly became skeptical. I'd read over on the SFF forums users pushing the HDPLEX had benefited from the larger gauge wire (stock being something like 19AWG). So that's the current plan. It's gonna be tight with just the larger diameter wire let alone trying to sleeve 24 cables in 4mm Teleios. I'll look at sleeving the accents.. fan wires, switch, the power connector cables. Maybe I'll sleeve a couple from the GPU/CPU, see if it looks good.
    I have a couple Parvum switches so thought I had this covered... turned out the S4 MINI uses a 16mm switch, oops. Not to worry, KUSTOM PC to the rescue. Again, room is super tight with the 24PIN mobo connection sitting right up in-front of the switch.
    This is the first project since moving house.. I've turned my office into a right state trying to find all my 'bits and bobs'. I'd convinced myself I had a stash of terminals, but could I find them... no. I'd convinced myself I had extra 22AWG fan wire, but could I find it... no. Luckily E22 hooked me up with a rapid resupply, thanks guys.
    With everything loaded up stock the system pulled just shy of 245W from the wall. looping the Unigine Valley Benchmark the Noctua NH-L9i kept my 95W i5 6600K under 40'c and silent whilst the stock cooler on the Gigabyte GTX1060 ITX OC maxed out at 62'c with the fan at 40%. Granted it's winter, I live in North Wales (it's cold) and without the HDPLEX fitted in place both components see better airflow. I was surprised all the same. Even so, I wanted to try removing the 92mm fan/shroud on the GPU and mounting a 120/12mm fan over the GPU instead.
    I think that looks ace! a pair of thick copper heat pipes, with the heat sink making contact on the RAM and VRMs (nice work Gigabyte).
    With the slim 120mm Scythe fan in place, the GPU fit perfectly (lucky!). I'm a huge fan of SpeedFan I've used it for years, long before PWM became the norm and manufacturers included half decent fan control software with their motherboards. So the plan was simple enough. Install SpeedFan, control the RPM of the 3PIN chassis fan based on the GPU temp. Only for some unknown reason SpeedFan was unable to see fans (thought it did detect the correct controller). A quick search found others with Gigabyte Z170 based boards experiencing the same. When it's all done, I'll come back to it.. I'm sure I'll find a fix. For now I used another little app to do the same (arhh, I can't remember what is was called).
    I ran the same loop of Valley and found the performance to be around the same. With one large difference. Whilst both solutions kept the GPU around 60'c, it took the Scythe running at 60% to pull it off. A touch too loud for my liking.
    The Gigabyte Z170N Gaming 5 only has two fan headers too, and I'd intended to make use of some Dazmod ridged LED strips powered from a fan header (makes for simple dimming control). By using the chassis fan, I wont be able to do that.
    That's it for now. Thanks for reading. What do you think, stick with the stock cooler or tweak the slim RPMs to reduce the noise and roll with it?
    J.​
  8. Goatee
    Goatee Multimodder
    19 Apr 2015
    Loving the build so far. I did some reading on the S4 mini after seeing your mod log started, its a cracking little case.
    If your struggling with running out of fan sockets for the RGB, have you considered a Aqua Computer farbwerk to control the RGB's?
  9. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Wow, talk about a pocket rocket! That looks very nice indeed. Thanks for giving me a heads up about the NFC case, too - I absolutely adore tiny mITX chassis and had somehow never come across that case before.
  10. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    They are a cracking piece of kit for sure. It requires molex which I'd rather keep away from. It's just because the connector on the PSU, with the position i have it in, is partially blocked by a cap on the mobo. NFC worked with HDPLEX on the revised layout on the 300W version which would solve this.. but I'll make do.
    It's a micro beast huh... haha, NFC have just restocked the S4 MINI too! this time round with a higher grade ALU and a Kensington locking point.
    I'm waiting on a couple side panels NFC are sending over. The intention being (at least currently) I'll model the panel and cut away the center to create a thin bezel framed panel. Have that powder coated to match the black interior panels then mount a tempered glass sheet approx 5-7mm clear of the frame (to allow airflow). I wanna create a mounting mech that'll allow for thumb screws and require the additional clearance to enable the use of a Noctua 92/25mm redux fan.
    That'll be the main mod to the chassis, I'm sending over some designs to coldzero for a GPU backplate and waiting on some wood I plan to experiment with.
    J.
  11. Parge
    16 Jul 2010
    So weird, literally just received an email from Josh about ordering an S4 mini and then this pops up. Loving the build so far. That spray painting job is unreal.
  12. B NEGATIVE
    8 Aug 2011
    Fanx.
    I take on jobs if anyone needs stuff done. You would have to ship it to Slovenia now I work at EK tho......
  13. Parge
    16 Jul 2010
    Its b.e.a-utiful.
    No doubt Hackjoe will ruin it for everyone by taking the rest of the pics in sepia or something ;)
  14. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Well, I'm jelly! The latest batch of S4 Minis use a higher grade Alu and have a kensington lock (something I certainly use at LAN events).
    I forget how you now have the greatest job on earth.
    I kinda like the B&W again now.. shares the progress visually without spoiling how the final build my look. As it's not a huge WC project and I've already posted the paint job, the B&W adds a little mystery. That being said... I'm certainly going with sepia in the next update! haha
    J.
  15. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    UPDATE 3.0
    Things have moved along a little further so I'm back again to share my progress. A few things have happened since update 2.0. NFC hooked me up with a couple extra side panels for whats coming up next :dremel: I bought some EK Monarch blocks for the RAM (not they'll be WC'd) to provide a little extra height between the DIMMs and the PSU.. lets start there, RAM.
    I'd never removed the heat spreaders from RAM before... years ago back when all RAM came naked, I added heat spreaders a time or two but never this way round. It was easy enough, I used a low temp on my heat gun and gently warmed up one side of the RAM at a time. Once warm I slid plastic card (like a gym or library card) in under the heat spreader. Repeated that a few times and off they popped.
    They look much better now.
    The majority of my free time over the last couple weeks has been spent on the wiring. I mentioned last time I'd intended on replacing the stock (thinner AWG) wires with new cables made with thicker 18AWG black wire. Well that turned into an epic battle between the function vs aesthetic gods..
    Oh, I put the cooler back on the GTX1060, it's a much tighter fit but the cooling (mainly noise) is so much better for it. I'll look at tarting it up a little down the road. The odd thing is.. the orange on the cooler matches the orange on the 960 EVO drive. As they are, the only two components you see on that side of the chassis, it sorta works... as is... But I guess we'll see.
    But anyway, you can see the 6PIN GPU cable. The stock HDPLEX cable is yellow/black 21 AWG (not sure...) wire with a single 8-PIN at the PSU end and a 6+2 x2 at the other. Strapped up, fitted, you could barely see the new cable.
    But then things started to get complicated, well, crowded. I made the 8PIN EPS which turned out okay considering it had to bypass the 24pin to be routed correctly. However the 24pin is where the battle truly begun. The thicker AWG added a lot of bulk compared to the stock HDPLEX cable (if you were to simply cut the stock cable to length). I reassembled the build and booted her up. everything worked a treat. But they really ain't much to look at..
    So the war begun.
    Bare black wires certainly look better then the HDPLEX cables but it's not much of a build without some sleeved goodness. Firstly, I had decided I had plenty of room to sleeve the EPS and GPU cables. I also took the HDPLEX power connector cable desoldered the stock wire, replaced with new wire and sleeved them.
    ATTEMPT TWO:
    I hated this when I did it*. the EPS cable looked smart, clean, the cable combs made a color combo work and pulled your focus. But the 24pin looked fat and untidy. I didn't like that the power switch red cables popped as they were much shorter then the others. I knew I didn't have enough room to sleeve all 24 but felt as the positioning would hide the others, sleeving a few would add something.
    *annoyingly, looking at it now. I kinda like it.
    The EPS was different, half the wire needed to remain bare in order to pass under the 24pin to get to its PSU connection. It was the pattern I didn't like. I love the colors, the chassis pulls cues from certain 'M' class BMWs with it's estoril blue paint job. The sleeve was picked to highlight aspects of the motherboard (the red DIMM and PCI slots) and to further that BMW scheme connection. The colors are a combination of the brand logo and the 'M' logo. So first time round It looked like this, a repeating pattern. But with only 8PINs it's too much and with only 6PINs for the GPU and 4PINs on the power cable.. I could not repeat the same pattern.
    So it didn't last.
    ATTEMPT THREE:
    I swapped the red switch sleeve for black and took the color out the 24pin. I went with 3 black to cover the bare wire beneath and one gray to pull in the Noctua Redux fan. I also redid the EPS wire (I didn't take a better photo...) I needed a pattern based on 4 wires, something I could repeat on the GPU and power cables. So I did. The EPS became gray, blue, light blue, red. With the remainder in black.
    I repeated the same for the GPU to match the EPS. At this point, had gone with 2x blue 2x grey on the power cable. It was getting there, but I still didn't like it. The 24pin still looked fat and untidy, I liked the use of combs on the GPU cable and was happy I'd found a pattern I liked but by matching the EPS it meant that you mainly saw the grey, red, black wires on the GPU cable when really you could only see the grey, blue, light blue on the EPS. So they looked totally different.
    So it wasn't to be.
    ATTEMPT FOUR:
    I had to do something about my fat untidy 24PIN. The main problem I was/am having is the 24PIN sits higher on the mobo then it's bottom edge on the PSU. So the cut lengths have to allow for a bridge type bend in the middle, A: to allow the PSU end to connect lower then the mobo and B: to run that 8PIN EPS under it.
    So this time round I thought I'd sleeve four cables all black on the 24PIN to hide the wires underneath. I also trimmed a few to drop the high point on the cluster of wires. I bound them to pull them in tight under the sleeved cables above.
    Which worked (for the most part).. it dropped the 24PIN cluster enough to make the 4PIN power cable (now grey, blue, light blue, red pattern) sit above it.
    I also took the GPU cable and flipped it, so the pattern would show more of the blues. Added more combs to the GPU and power cable then reworked how the power cable routed through the chassis to the PSU.
    and that's where I'm at... do I like it? no. Do I like it better then the previous attempts? sure. I don't really like the look of cable combs and don't feel my runs are quite on point. But I keep telling myself it's not finished.. I've got the back plates coming and the frame side panel to come, then a glorious tempered glass pane to finish it off. So for now, I'm leaving it. I need to move forward with those two bits. Once they are in, If I still don't like, I'll try again. It's all a process.
    Thanks for checking it out. What do you think? Should I go back to bare wire? try a different color combination? rework the lengths? or do you like it?
    J. ​
  16. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    UPDATE 4.0
    Back again with another little update. Not a great deal has progressed over the last couple weeks (mad how quickly these weeks seem to fly by) my other half is unwell, and caring for her is slowing things down. Which, in this moment, made me think of this scene from Monty Python the Holy Grail... start at 0:50.
    https://youtu.be/grbSQ6O6kbs?t=55
    Hahaha, so, whats cracking. well, a few things. Firstly, I'm redoing all the cables. But I'm doubling up rather then starting over. Which meant another visit to E22.
    I've bought enough terminals and wire/sleeve to make a second 24pin. I had an idea to separate the two rows of 12 wires, dropping one row down, to run along side the other. It's difficult to visualize but I think the end result could be good. keeping the bulk of the 24PIN down at the floor of the chassis. It's just an idea, we'll see how it turns out. If it's a success and I'm left with enough supplies I'm going to make a second (third if you count the factory HDPLEX cables) set of EPS and GPU cables. I'm pretty happy with those as they are, but whilst I'm waiting on some of these other bits (I'll cover them a little further down) it's nice to stay busy. Plus, I'm going to drop the red from the sleeve pattern and maybe the lighter blue too.
    The extra two side panels turned up (Thanks again Josh) in a textured black powder coat (which I really like). But it's gotta go. A buddy has a homemade sand blaster set up in his garage (he uses it to engrave and sell slate souvenirs), he thinks he can strip the powder coat with relative ease (I'll take some pictures when he goes it, let you know how it goes).
    Once stripped, I'll be sending both panels down to the wonderful B-NEG for some special attention. Dan is going to CNC the middle section of the panel and and cut the mounting points for the glass. I'm currently working on the CAD for this, although it's not going that well. Fingers crossed, the blasting will happen next week and I'll be able to get the panels off to NEG in time for his next visit home.
    I had been on the fence with this one.. originally I'd wanted to fit a small 12x2 display into the Alu wrap-around of the chassis. The inner chassis frame has a perfect cut out for this directly behind the GPU and if you were so skillfully inclined you could pull it off. Only I've gone with a GPU that is at the upper limits for the S4 Mini to house comfortably and to mount such a display directly behind such a GPU, whilst possibly, maybe, possible... it would certainly have a knock on effect to your thermals, perhaps damage the display too (pretty sure they are rated <60'c).
    So what to do..
    Well, I bought a bigger one. THIS ONE to be exact. I know I've already mentioned it, but if you're in the UK, the guys over at Kustom PCs do a bang up job. They have a truly great selection of products. I used one years back on a build I'd done in the Silverstone FT03.
    They are great little displays and very easy to program. I was looking at the layout of the motherboard and spotted the internal USB header is placed just below the PCI slot (the display is USB), and once I've put the glass side panel on it's not as though this build has lots of epeen watercooled glory to behold. so I thought..
    The USB header is directly beneath it, making connecting it simple and clean. The module is the exact width to nicely fill that space between CPU and GPU too.
    Mounting it should work out pretty well too. I plan to use the 120mm fan mounting holes above the IO. I'm working on the design atm (I'll share my designs in the next update). The plan is to frame the display, with the mount also framing the the Noctua cooler (on two sides). That should nicely hide the IO and cover the nasty green PCB on the display. I'm working on the mount being made from 3mm ALU which I'll powder coat along with the side panel frame to match the rest of the internal powder coating. If it all goes to plan the mounted position of the screen will run flush with the GPU once that has it's custom back plate.
    That's it for now. I'm hoping as my other half continues to recover I'll be able to put more time back in to this, I'm pushing to have the CAD work finished in the coming week so I can finalize dimensions for the mounts on the glass. I'm attending Insomnia 60 in April and this is coming with me.. so ultimately that's the completion goal.
    Hope you enjoyed this little progress report, I'll come back soon with designs for you guys to give me some feedback on.
    Cheers
    J.​
  17. Parge
    16 Jul 2010
    I can only be so aroused......
    Also, I'm enjoying all the back and forth with the cables. Its almost like a little story in itself. I've emailed Shrop (pexon) from this forum about getting some made up for the HDPlex myself, but not heard back. The stock cables could not be more garish if they tried!
  18. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Haha, the cables are easy enough, Pexon will do an epic set for the HDPLEX. The stock cables are a thinner gauge and Pexon use good quality wire so they'll be stiff! I'm happy enough with my cables, just, feel I can do better.. haha.
    The HDPLEX rocks!
    J.
  19. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    UPDATE 5.0
    Nothing too exciting folks, life has been hectic but I wanted to touch base and share the little news I've got. With Insomnia 60 (LAN) just a couple weeks away it seems I'm not going to finish this build in time. Which is disappointing but fine. I'm not letting anyone down, it's not a show piece and it'll still be coming with me.
    I'm still to send the side panels down to B NEG for some CNC love and until I do that I can't finalize dimensions for the glass. But it's all in hand and we'll get there.
    So what have I gotten done.
    Ricardo over at COLDZERO (check em out if you've not already) hooked me up with the backplate mock up (top left, above). Which I'm pretty much happy with. Think I'll drop the NFC logo from the backplate and put it elsewhere. Maybe add a little 'sponsored by' or 'powered by' to proceed the E22 and GIGABYTE logos.
    You can also see, I've pretty much finished the bracket design. The original was intended to be ALU (and it may go back to being so if this doesn't work out) but I had a thought, why not have it match the backplate. So I reworked the design and sent it over to Ricardo.
    All being well it'll have the same design vents as the backplate running along that chassis mount side (to help clear the air kicked up from the CPU heatsink and should fit just about flush with the GPU. Fingers crossed those two bits will be with me before LAN.
    In other news, we've finalized the design for MODZERO JABBA (the next project), that'll be coming this summer. Can't wait to show you guys!
    This weekend I hope to remake my cables, so I'll report back then. :thumb:
    J.​
  20. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    UPDATE 6.0
    Multiplay Insomnia Gaming Festival 60 is but days away! JUICE was always earmarked for competition in time for this event. It is after all, primarily my new LAN rig. That wasn't to be, with a number of speed bumps along the way, sadly JUICE won't be finished in time for LAN. But it will be coming..
    Oh yes, I present, MODZERO JUICE STAGE 1.0...
    or at least I will present it a little further down... sorry.
    JUICE is running off a single 960 PRO 256gb NVMe drive, I'd not intended to add anymore storage. But will all my games installed on two 250gb SATA SSDs in my main rig and LAN being so soon, I thought about how best to make use of those SATA SSDs.
    So I bought one of these..
    I thought, I'd pull the two drives from my other rig, label them and hot-swap between the drives as and when. But, I had visions of losing a drive or disconnecting it when in game. So I went a different route.
    The NFC S4 MINI can mount two 2.5" drives in front/behind the GPU. Yet I'd previously written this mounting option off for three reasons.
    1. Knowing I was putting a toasty GPU in there I'd always thought the SSDs would get cooked
    2. The HDPLEX molex/sata power connection on the PSU was tucked in tight at the back of the chassis partially under the motherboard.
    3. I'd not seen anyone else fit the drives and do a cracking job of the power/sata cable routing.
    Challenge accepted.. :rock:
    Firstly I took my two drives (two different drives) and covered the backside in matt black vinyl. Mounted them on the cage then proceeded 'to throw all the toys out the pram' when I couldn't find the two last screws... (They were holding my power connection in place... why I used two of the screws for this job I've no idea...)
    It was almost a none starter.. not only is it tight, but the cables actually foul the clear CMOS pins on the board. I'd had to be sure the wires ran between the pins... the whole build would have to be dismantled to sort that, had it been the case.
    With a sizable gap between the CPU cooler and the PCI riser (where my Matrix orb will be fitted) I planned to run the SATA power cables directly down to the PCB and across to the PSU.
    I'm not a huge fan of heatshrink cables and SATA (at least this choice of connector) is level leet when attempting the heatshrinkless approach, alas I'm not pOpe so I rolled with it (I'm already planning to redo it when I move on to Stage 2).
    Not a flattering angle, but you get the idea. I'd just been training the bends and had sagged the sleeve. :rolleyes:
    With it fitted to the SSDs, now came the PITA. I'm not all too confident with soldering, but how else am I going to get any better. With the harness in place and the PSU in there too, I had a lot of already short cables to shorten and solder... with the prospect of starting over if I messed up (I only had the exact number of SATA terminals) hanging over me, a mistake at this point would have been a rage quit. haha..
    Done, all the connections were solid, the heatshink suffered as the wires heated up but with that end of the loom being down running along the PCB I wasn't too concerned.
    Next was the bloody 24PIN, well, all the other cables really! If you've been following along you'll remember I've not been a huge fan of my pervious efforts. I loved the colors... individually, but struggled to make them work once fitted in a combination that really blended with the color scheme.
    I touched on it a couple updates ago (I think) but I'd bought more sleeve in just the blue and the grey. So the plan was to re-sleeve the GPU, POWER and CPU. Then make a new 24pin.
    The old one was just a little too long in many of the wires which caused it to push up against the RAM more then I'd like.. I took my time, dropped the partial sleeve from last time and it worked out much better IMO.
    This time round i was able to have the PSU end come up from the bottom, which would enable to power adapter cable to run flush over the top, much better then before.
    Lastly I used more of the matt black vinyl to mute the silver/red motherboard stickers.
    SO....
    It's not finished....
    But.
    What do you think?
    J.​
