PSU PSU for GTX 560 Ti SLi
Discussion in 'Hardware' started by popcornuk1983, 21 Apr 2012.
  1. popcornuk1983
    popcornuk1983 Cake or Death?
    3 Sep 2008
    Hello all.
    I'm thinking about adding a second GTX 560 Ti to my PC. I'm wondering what the minimum wattage should be for this setup. Rest of my setup is in the sig.
    Cheers for any suggestions!! :D
  2. Plodder
    Plodder What's a Dremel?
    14 Apr 2012
    I think your cpu is already a bottleneck even with 1 GTX 560 Ti. I doubt you will see any performance gain from sli with that setup tbh.
  3. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    ^ This. You'll have to upgrade your CPU first.
  4. mattyh1995
    mattyh1995 Minimodder
    1 Oct 2011
    While true, it's not what the OP asked.
    Use http://www.extreme.outervision.com/psucalculatorlite.jsp to work it out. I'd guess around 650W? But i've not worked it out.
    popcornuk1983 likes this.
  5. feathers
    feathers Minimodder
    11 Apr 2009
    I ran dual 560Ti for a year on my 625w enermax PSU. That was even with the previous i7 860 at 4ghz. DX11 games like BF3 and Crysis 2 were using between 400 to 620 watts peak. The enermax barely got warm and never had issues. A good brand 625+ watt PSU should be fine. I have used Enermax for many years cos they are reliable. Even when it was fully loaded you couldn't hear the fan.
    The 620w peak draw was for my entire PC excluding the monitor.
  6. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    A good quality 650W PSU should do you fine but personally I'd go for 750W or above. It depends how much you want to spend.
  7. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
  8. popcornuk1983
    3 Sep 2008
    Thanks for the suggestions guys, I already have a 750W XFX PSU. I was just wanting to make sure that I had enough grunt to run the two cards.
    I'm budgeting for the second part of my upgrade and wanted to know if I needed to add extra funds for a PSU. I don't. Woo!
    I know about the Q6660 being a bottleneck. A friend has the the same gfx card as me but he has a i7 system and gets about 20-25fps more in games like Skyrim. I'll be upgrading that first before buying the second card.
    Cheers again :)
  9. Plodder
    14 Apr 2012
    Great, by the way i have an xfx 750w xxx as well, fantastic psu. :thumb:
