Modding Cube - X
Discussion in 'Modding' started by andrewadanza, 19 May 2015.
  1. andrewadanza
    andrewadanza What's a Dremel?
    4 Nov 2014
    Introduction:
    Hi Guys,
    First of all, I'm Andrew Lee Adanza. I've been a pc enthusiast for just about a 2 years or so. Building a gaming rig was only my goal at that time. But as time/months passed by, my love for PC grew. That is the time when i was hooked up to modding. Right now, i'm in a foreign land and it is hard for me to grab all tools and materials to do modding since im still not familiar in this country. Anyways, I will stop this nonsense and proceed with my build log. :D
    I've already seen and followed some epic system builds and project logs creating a case using acrylic. some of these are wallmounted pc's like LORAMENTUM and some build using PARVUM like Darthbeavis, l3p, kier etc. This guys inspire me. so now, I will be creating a case with the idea of a case made of acrylic like PARVUM but with inline loops(coolant will pass in the case itself, like LORAMENTUM). If my work comes out half as good as other "masterpiece". It would be a great achievement for me.
    All cuts are done using a scrollsaw and by hand. hoping to have my own laser cutter to ease the work. ;)
    I would also like to take this chance to say thanks to all of the sponsors.
    Thanks BITFENIX for sponsoring this build.
    Special thanks to BitFenix Malaysia and Clement for all the help.
    Thanks CORSAIR for sponsoring this build.
    Special thanks to Corsair Malaysia, Emily and Anson for all the help.
    Thank you guys.
    I would also like to give thanks to Intel and Intel Malaysia for helping me on this build.
    Thanks a lot guys.
    And to my wallet. :D :p :lol: ^_^
    hehehehehehe....
    Hardware List:
    Below is the list of parts/hardwares to be used in this build.
    Specs:
    CPU: I7 4790K - ✓
    MoBo: Asus Z97i - Plus - ✓
    RAM: Dominator Platinum 2400mhz - 2 x 8gb - ✓
    GPU: GTX 760 - ✓ (to follow, all budget for GPU goes down the drain with all the tools and materials needed for this build.) :D :)
    HDD: WD 500gb - ✓
    SSD: Corsair Neutron 240gb
    PSU: Corsair AX760 - ✓
    Water Cooling:
    CPU Block: EK Supremacy CPU Block Nickel Plexy - ✓
    GPU Block: EK FC670/760 - ✓
    Rad: Black Ice GT Stealth 240 XFlow Rad - ✓
    Pump: EK DCP 4.0 Pump - ✓
    Reservoir: D65 x L170mm RES - ✓
    Fittings: Compression Fitting - ✓
    Fittings: 45 Degree Adapter - ✓
    Fittings: 90 Degree Adapter - ✓
    Flex Tube: Primochill Advanced LRT Tube - ✓
    Coolant: Mayhem Pastel Green/Mayhem Blue Dye/Mayhem UV Green-Yellow Dye - custom color - ✓
    MODS and Misc:
    Fans 1: CM JetFlo 120 2pcs - ✓
    Fans 2: CM XtraFlo 12CM 2pcs - ✓
    Led Lights: BitFenix Alchemy LED Strips(white) - ✓
    Sleeved Extension Cables: BitFenix Alchemy Cables - ✓
    Corsair Lightbar Kit
  2. Afterice
    Afterice What's a Dremel?
    5 Jun 2015
    Cube X
    OH RLY All of Friday i was thinking of making a spartan in assult cube but i was only going to edit "skin"
    And I mean what program did you use to make the skin.
