Case Mod - In Progress ECM-7 BW - Project complete -
Discussion in 'Project Logs' started by Elladan, 12 Aug 2014.
  1. Elladan
    Elladan Minimodder
    17 Mar 2012
    Hi dudes!!!!
    After a long break, I am finally back with a new project. This time, it's for a case mod, I'll start another scratch build later.
    This mod will be based on a Bitfenix Ronin
    First of all, I do thank Bitfenix and Aquatuning France for their sponsoring :thumb:
    Concerning
    hardware:
    - MSI Z97M gaming
    - Intel I5-4670K
    - 16Go Avexir Blitz 1.1 2133Mhz
    - MSI gtx 680
    - Bitfenix Fury 650G
    - SSD kingston Hyper X 120G
    Watercooling:
    - WB CPU Alphacool NexXxos
    - WB GTX 680 Alphacool NexXxos with backplate
    - res aquatube
    - fittings 16/10 Alphacool black
    - tubbing Masterkleer 16/10 white
    - rad XSPC 240 and 360 crossflow
    - DDC 18W + top EK
    Here we go!!!
    To begin with, I cut the top for the rad which will takes place between the plastic and the metal structure of the case
    and cut a long aluminium and PVC piece which will cover the front and top of the case
    Having received my parcel from Bitfenix and Aquatuning France :clap:...
    ... I started working on an aluminium piece for the bottom of the Ronin to put rad and PSU
    and an other piece to keep the PSU plug at the same place
    Today, I have worked on cutting Bitfenix's logo on the front panel and air vent on the top
    Now, I have to find a way to create a great backlightning on the white acryl :confused:
    More pictures soon, and I hope you'll like this project
    see you ;)
  2. chilliewillie
    chilliewillie What's a Dremel?
    14 Apr 2014
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That is looking great!
  4. Elladan
    Elladan Minimodder
    17 Mar 2012
    Thanks guys!!
    Oh, I forgot to put a picture of a render. This mod should look like this at the end ;)
    Surely with some modifications during the built :D
  5. DeMoB
    DeMoB All of my Dremel wheels are broke!
    10 Jul 2008
    That custom 'light shroud' around the outside of the case is a nice touch!
  6. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    :thumb::clap::thumb:
    Me likey
  7. Elladan
    Elladan Minimodder
    17 Mar 2012
    Hello guys!!!
    small update :clap:
    I have worked on parts for the bottom of the case.
    I cut 8mm acryl to strengthen the part which supports the Fury
    It also allow to create a compartment to use a 80mm fan to directly extract air from the PSU.
    Second part of the work was to create a fan grill with white acryl. I thing I will use backlighting here too.
    that's all for today.
    See you :thumb:
  8. Elladan
    Elladan Minimodder
    17 Mar 2012
    Hi guys,
    I have been working on the I/O panel this week-end, some pictures
    I cut 2 pieces of 8mm acryl to maintain the PCB
    And cut the aluminium on the front panel
    Update soon :thumb:
  9. Elladan
    Elladan Minimodder
    17 Mar 2012
    Hello!
    it's time for an update :thumb:
    I've worked on the inside of the case, creating a piece with aluminium. I kept the original design of the PSU/bay cover
    It still needs some finishing works, I'll do it soon.
    I take some times to make some photo of the watercooling parts sent by Aquatuning.fr
    Cape fuzion 100
    Alphacool cool fitting ( matt black )
    That's all. No modding this week end, I have to do a review and test of the Bitfenix Fury 650G
    See you ;)
  10. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Nice scroll saw :)
  11. Elladan
    Elladan Minimodder
    17 Mar 2012
    Hi guys !!!!
    Some news about this project. Two news sponsors will help me for the built, Avexir, who sent me 4x4Go Blitz 1.1 2133 Mhz :thumb:, and Royal Covering with a roll af black brushed titaned vinyl :rock: whick must arrive soon.
    Of course, I had to change the color of the Ram :D
    Concerning the mod:
    I have really few space to use the cape fusion, so I will use an aquatube.
    I finally decided to change the MSI MPower Max for a MSI Z97M gaming ( with a small paint job too )
    I worked on a new stand for the 360mm rad for the top
    I also worked on the gpu's backplate using an alphacool for base. I cut white acryl and add some aluminium pieces. I am just waiting for the vinyl to finish it.
    With those modification, I could finished the watercooling loop. I use rigid tubbing/fitting to connect the GPU.
    I will not keep the part for I/O panel with usb and audio, I don't really need it. It will give a better look to the front of the case, more simple.
    Updates will arrive soon, stay tuned
  12. b2bk
    b2bk What's a Dremel?
    11 Jun 2014
    i like the logo of front case
  13. Elladan
    Elladan Minimodder
    17 Mar 2012
    Hi modders!!
    I hace finally received my package with all the vinyl needed to continue the mod :thumb:
    A great thank to Royal covering for this nice gift :cooldude:
    I started the covering with the modded Gtx 680
    Hope you like it?
    New update before the end of this week
  14. GZ-JR
    GZ-JR What's a Dremel?
    6 Oct 2014
    wow awesome work
  15. Cheapskate
    13 May 2007
    Looking great.:D
  16. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Very interesting look, not sure how I've missed this before today!
  17. Elladan
    Elladan Minimodder
    17 Mar 2012
    Thanks dudes :thumb:
    I started the covering today, pictures soon :p
  18. bulldogjeff
    2 Mar 2010
    This is proper modding. A load of tools some good ideas and a skilled hand.. Nice work dude.
  19. Elladan
    Elladan Minimodder
    17 Mar 2012
    Next mod will be ten time proper, a CNC is coming soon ;)
  20. Elladan
    Elladan Minimodder
    17 Mar 2012
    Hi!!!!
    Covering still under progress, there's only one piece to do now :thumb:
    I use some coat to fill the CPU waterblock and put an holographic vynil
    The others pieces done
    A bitfenix's logo cut in a black vinyl and put on the res
    And finally, the acryl tubbing for the GPU
    That's all, more pictures soon :naughty:
    See you
