Could not connect to Assignment Server
Discussion in 'bit-tech Folding Team' started by Scorpuk, 4 Feb 2012.
  1. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Both CPU and GPU console clients reporting this for past two hours.
    Any help?
  2. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    You can get info about the status of all the servers by going to http://fah-web.stanford.edu/serverstat.html. If the server your client is trying to reach is down, it sometimes helps to shut it down and restart in 30 seconds (30 seconds makes sure it has cleared from memory), which can get you connecting to a different server.
  3. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Things should be back up and running now ....
  4. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Yup all back up and running now. :thumb:
    Tnx all. :)
